Poormans Pushrod Unbending LOL
Re: Poormans Pushrod Unbending LOL
Postby Altransit » Tue May 04, 2010 10:18 pm
You don't need heat, just straighten them cold :!:
Postby MrMPuk » Tue May 04, 2010 10:19 pm
The blow torch will take the hardening out of them so no the blow torch wont help. They really aren't that hard to straighten.
Postby fordmaniac » Tue May 04, 2010 10:19 pm
hey scotty that remark you made before mate was a classic!! im still laughing now! the sense of humour on the forum is brilliant!!! cheers gaz
fordmaniac
Postby sidspop » Tue May 04, 2010 10:48 pm
MrMPuk wrote:You wont damage the tops or bottoms, they are hard as sh*t.
Would that be as hard as a sh*t after a ruby murray, or a constipated sh*t?
sidspop
Location: The Black Country (near to Brummagem, but not the same)
Postby thedadio » Wed May 05, 2010 12:09 pm
Update: Right My knee is hurting and i have splinters in my mouth but my rods are straight(ish). The rocker assembly is back on and the none of the rods bent when tightening it down so i must have the timing setup correctly, Yay. So after a 4 mile walk (round trip) to Unipart, the parts havent arrived :-(. This is the third time this has happened to me with them, but i cant complain as the parts are so much cheaper than anywhere else.
54 plate 135 T350 Lwb rip
13 plate 125 jumbo rip
54 plate connect tdci rip
60 plate 85 T280 rip
57 plate 85 T260 (lieutenant)
63 plate L2 H1 125 limited (new recruit)
thedadio
Postby madbri » Wed May 05, 2010 12:16 pm
thedadio wrote:Update: Right My knee is hurting and i have splinters in my mouth but my rods are straight(ish). The rocker assembly is back on and the none of the rods bent when tightening it down so i must have the timing setup correctly, Yay. So after a 4 mile walk (round trip) to Unipart, the parts havent arrived :-(. This is the third time this has happened to me with them, but i cant complain as the parts are so much cheaper than anywhere else.
tip of day :wink: phone first :lol: :lol: :lol:
madbri
Postby scotty281976 » Wed May 05, 2010 12:28 pm
fordmaniac wrote:hey scotty that remark you made before mate was a classic!! im still laughing now! the sense of humour on the forum is brilliant!!! cheers gaz
glad you liked it it :lol: i couldnt help myself
2011 mk7 ex rac 140t330 awd
scotty281976
Postby thedadio » Wed May 05, 2010 3:14 pm
Question... How neccesary is it to use thread lock?? And Liquid Gasket? Anyway Water Pump is on minus liquid gasket and threadlock ,and torqued up (Found the settings in the forum thanks). Cambelt is on tensioned and timing checked and checked again (manually span the engine a few times and made sure all Timing pins (drill bits) slotted in.
Can anybody furnish me with the torque settings for timing belt tensioner and rocker assembly bolts? I have searched the forum but could only find torqe settings for water pump and rocker cover. Thanks in advance!
thedadio
Postby jay » Wed May 05, 2010 4:22 pm
rocker pedastal bolts m8 bolts =26 to 32nm or 19 to 24lbf
m10 bolts=63 to 69nm or 8 to 10 lbf
mk1 connect tourneo
jay
Postby thedadio » Wed May 05, 2010 10:12 pm
Update ALL DONE!! Went to the shop bought feeler blades locktite and a bit the bullet and bought a haynes manual simply for the torque settings. Anyway all good, motor running sweet, its done 90k and it was still on original cambelt and water pump ?? Anyway all good, so if there is anyone in the slough and surrounding area who needs me to change any bits on the front of their motor/servicing, or simply needs help just pm me and ill be happy to help thanks!!
Thanks so much for everyones help really appreciated!!
thedadio
Postby Altransit » Wed May 05, 2010 10:35 pm
thedadio wrote: Thanks so much for everyones help really appreciated!!
:D 8)
Postby johny transit » Thu May 06, 2010 11:41 am
That sounds the worst of the lot - heating them really will change the nature of the steel, surely?
"There's always a way"
johny transit
johny transit
Postby stalwart » Fri May 07, 2010 9:25 am
90k and it was still on original cambelt :?: :?:
So how did the rods get bent in the 1st place,this is summit that happens when a cambelt gos,init :?
I'd have change that cambelt as well otherwise you may end up getting out that block of wood again :(
stalwart
Postby Altransit » Fri May 07, 2010 9:33 am
stalwart wrote:I'd have change that cambelt as well otherwise you may end up getting out that block of wood again :(
He has changed the belt because it stripped the teeth and bent the pushrods ............. it's all in his first post :wink:
Postby stalwart » Fri May 07, 2010 10:04 am
DOH :oops:
stalwart
