wiring a towbar
wiring a towbar
Postby wmw1 » Thu May 06, 2010 7:48 pm
Hi all. got a s reg 80 swb and have just bought a second hand tow bar and was wondering if anyone has got a diagram of how the wires go ( coulors etc ) any help would be appreciated.
wmw1
Re: wiring a towbar
Postby poppyabe » Thu May 06, 2010 10:14 pm
yellow lh ind blue fog white earth green rh ind brown rh side light red stop lights black lh side light hope this helps
poppyabe
Re: wiring a towbar
Postby wmw1 » Thu May 06, 2010 10:25 pm
Thanks yes that helps, what is the best conectors to use? and do i just conect direct to the wire going to the corisponding bulb on the light cluster and fix the earth to the body
wmw1
Re: wiring a towbar
Postby poppyabe » Thu May 06, 2010 10:27 pm
solder them and shrink sleeve it u want them to last and yes find live to each light in loom or near rear light and wite sraight to body
poppyabe
Re: wiring a towbar
Postby wmw1 » Thu May 06, 2010 11:45 pm
thank you.
wmw1
cron
