custom trim
custom trim
Postby M3Stig » Wed May 05, 2010 9:53 am
on the custom trims that go down the sides, is there a part of that goes under the fuel filler cap? or just down the doors and main pannel ?
M3Stig
Re: custom trim
Postby trigger » Wed May 05, 2010 10:41 am
Yes there is a bit under the filler cap
Mk5 Transit the daddy
trigger
Re: custom trim
Postby topfuel » Thu May 06, 2010 5:28 pm
hi ! as for that part on a transit iv'e never seen one ? because mine hasn't got it , but i have got all the other strips though ! or is mine just missing as well ?
topfuel
Re: custom trim
Postby trigger » Thu May 06, 2010 7:08 pm
Yours must be missing, maybe the diesel overspill attacks the adhesive and they fall off
trigger
Re: custom trim
Postby Altransit » Thu May 06, 2010 8:49 pm
trigger wrote:maybe the diesel overspill attacks the adhesive and they fall off
Yes it does :roll: Mine is off at the moment, for the second time! I'm using 3 strips of "no more nails" double sided tape this time :P
Re: custom trim
Postby AndyG » Thu May 06, 2010 11:29 pm
Image :wink:
Re: custom trim
Postby trigger » Thu May 06, 2010 11:41 pm
I take it that was before the accident Andy
trigger
Re: custom trim
Postby M3Stig » Fri May 07, 2010 11:58 am
right well in that case i have the door trims and the rear bits if anyone wants to buy them?
M3Stig
Re: custom trim
Postby trigger » Fri May 07, 2010 12:02 pm
Why not just fit them to your van and then buy the bit under the fuel cap seperately
trigger
Re: custom trim
Postby MrMPuk » Fri May 07, 2010 1:17 pm
trigger wrote:Why not just fit them to your van and then buy the bit under the fuel cap seperately
No longer sold by Ford. :(
Re: custom trim
Postby Cooter » Fri May 07, 2010 1:42 pm
I'll have them, if they are still in good nick. Exactly what do you have though? All the black rubber stripes apart from the bit underneath the filler cap bit? And whereabouts are you and how much?
Always smileying!
Cooter
Re: custom trim
Postby M3Stig » Fri May 07, 2010 8:15 pm
they are painted in blue at the min, as i pulled them off a tourneo and got a couple of other bits off it aswell, £25 plus postage sound ok ?
M3Stig
Re: custom trim
Postby trigger » Fri May 07, 2010 10:02 pm
Get one from a scrappy or someone breaking a Tourneo
trigger
