Transit MK6 batteries seem low or not charging
Postby raybla » Thu May 06, 2010 10:12 pm
Hi have Transit mk6 minibus - replaced two batteries under seat for new also new alternator - but starting is difficult seems like not charging or being drained any help or known faults - thanks guys.
Ray
raybla
Re: Transit MK6 batteries seem low or not charging
Postby poppyabe » Thu May 06, 2010 10:37 pm
normally starter motor problem full of clutch dust if its more of cranking problem
poppyabe
Postby raybla » Fri May 07, 2010 9:13 am
Hello thanks for your reply - Someone else told me this and you confirm that I should look at this starter motor I will have ago at removing it over the weekend and post back later.
thanks poppyabe
regards Ray
raybla
Postby raybla » Mon May 10, 2010 4:44 pm
Thanks for your help poppyabe you were right starter motor just about knackerd decided to put on a new one - problem sorted.
regards
raybla
Postby MrMPuk » Mon May 10, 2010 4:49 pm
Probably need a new flywheel as well otherwise you'll be replacing the starter again soon.
Postby raybla » Mon May 10, 2010 8:42 pm
Ok thanks for that advice MrMPuk another big expense then - never had all this with my smiley.
regards
Ray
raybla
Postby Altransit » Mon May 10, 2010 9:10 pm
raybla wrote:never had all this with my smiley.
Shhhhh ....... don't say things like that :shock:
You'll start up the Mk5 vs Mk6 arguments again :roll: :lol: :lol: :lol:
Postby jay » Mon May 10, 2010 9:17 pm
was ther starter full of brown dust??if so as mpuk say flywheel on the way out..
mk1 connect tourneo
jay
Postby poppyabe » Mon May 10, 2010 10:12 pm
if u do deicide to do clutch and flywheel do ur self a favour and convert to solid flywheel they are cheaper then dual mass replacment and no more agro
poppyabe
Postby raybla » Mon May 10, 2010 10:57 pm
Hi yes some brown dust but not to much just thought that as it was out of the vehicle I would renew it - point taken about the flywheel replace with solid type - many thanks for all your comments guys.
Ray
raybla
