Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Mk1 Minibus V6 24v cosworth
Postby bikemad » Thu Jan 14, 2010 7:21 pm
just been looking, the 24v std bottom end can take up to 350bhp, if you run a single turbo use no more than 8 psi. thought you might want to no. also did you no that if you used a bob bottom end with a boa topend you will raise the compression to 9.1 producing 260bhp. also using tubuler manifolds would give you an extra 10 to 15bhp. check out passionfords website blokes on there been doing alsorts of things. :wink:
bikemad
Cosworth Powered
Cosworth Powered
Postby bikemad » Thu Jan 14, 2010 9:49 pm
check out poweredbyford website to :wink:
bikemad
Cosworth Powered
Cosworth Powered
Postby Luke » Sun May 02, 2010 7:18 pm
thought i'd update this as i've not done for a while :|
i had a leak on the timing chain tensioner and all of a sudden it became too bad to even drive so i set about doing it - easy enough job but a pain to get to alt, pas pump bracket all need to come off, also the plenum and cam covers to lock the cams while the tension is off the chain - anyway all done and so far doesnt leak :D
i'm after a new plenum as the one i modded is a bit ruined :oops: but to fit it i need to fit a smaller servo - i'm thinking about a mk6 one as it's narrower but the other thing i thought of is do away with the servo all together and fit an abs pump but without the abs bit - but thats another thread alltogether as i'm not 100% sure how they work and if they would be ok without abs :?
the other mod i've done to it is fit a towbar :mrgreen: a nice one :lol: i need it as i've provisionally bought a caravan :| just to put me on untill the camper's done :D
i'll post some pics of the towbar later :D :D
Postby BROWNYS V6 » Mon May 03, 2010 8:55 am
luke if you cant get a plenum up your way, theres one in our workshop at work as we still have them 2 cossie engines under the bench :wink:
BROWNYS V6
Postby Luke » Sun May 16, 2010 11:19 am
Postby Luke » Sun May 16, 2010 11:22 am
just to add, the towbar was off a mk4 to fit these to the earlier vans they do need a slight mod the holes for the bracket were 12mm instead of 10mm and slightly in the wrong position - so i redrilled 4 new holes and it fitted perfect as the chassis rails are exactly the same width :D
Postby AndyG » Sun May 16, 2010 12:44 pm
Very smart 8)
Postby bortaf » Mon May 17, 2010 1:25 am
Luke wrote:thought i'd update this as i've not done for a while :|
i
There's quite a few 24V cortinas running the sierra ABS pump and master without the ABS, the bloke who does the conversions runs the pump from an ign live i believe.
Ford power is a top forum for 24V info 8)
Current fleet
Mk7 transit ambulance
Mk1 Mondeo 1.8 STD
Mk5 fiesta 1.25
Mk6 fiesta 1.4TDCi
bortaf
Postby MattBlackMinibus » Sun Jun 06, 2010 8:47 am
Totally irrelevant to what's going on in your thread at the moment,
but just seen this and HAD to share ...
Shame I can't find more info on it :( Sorry
Nice work though, eh :!:
Starting All Over Again
MattBlackMinibus
Postby madmark » Sun Jun 06, 2010 5:21 pm
:shock: :shock: :shock: :shock: :shock:
Postby Gavin » Sun Jun 06, 2010 5:47 pm
thats the middle cans on a granny, those turbos must come through the floor behind the front seats!! bet the turbo lag is a postcode away!!! :shock: :shock: :shock:
Gavin
Postby Luke » Fri Jul 02, 2010 4:28 pm
next bit of progress :D i'm fitting front electric windows 8) 8)
i've bought a conversion kit for £60 the same type as sundowners as shown here in his excellent how to fit electric windows to a mk1/2 transit guide 8)
i've got 1 working now and it works a treat :mrgreen:
Postby BROWNYS V6 » Fri Jul 02, 2010 5:08 pm
we bought a set of them for wifeys capri :) did'nt use em though so there going in one of me transits :lol:
BROWNYS V6
Postby Luke » Fri Jul 02, 2010 5:22 pm
BROWNYS V6 wrote:we bought a set of them for wifeys capri :) did'nt use em though so there going in one of me transits :lol:
they'd fit perfect in the mk2 8) only difference i did to what sundowners done was mount them further down in the door to give me more room for a speaker and where he's cut a slot i've cut a hole and poked the end through :D
i was gonna take a video of them working but i cant seem to get my camera to video :? mabe it doesnt have that feature :lol:
next job a couple of speakers :arrow: viewtopic.php?f=13&t=68999 :D
Postby ginsambo » Sun Jul 04, 2010 9:59 am
Luke have you towed anything yet with the 24V?
Has anyone ever towed two tonne with a 24V granada scorpio? Should be OK you think? - As I remember the torque curve was still better than the Di, even at low rpms. Just wondered what damage it might do as those six cylinders are smaller and its petrol...if any? :D
My Mk5 was biodegradable and disintegrated with time.
Ford. Committed to the Environment
Finally entered the 21st Century and bought a MK7. Oh Dear.
ginsambo
