Next Job To Be Done
Next Job To Be Done
Postby Jon Boy UK - Wales » Wed May 19, 2010 6:22 pm
Hello All,
I have had the centre bearing/bush on prop finally renewed at last as it was very worn (alot of momevent).
What a difference to the noise level etc etc...Joy!
Now what job would you recommend i get sorted next.....
Steering Department...
1)Both rack boots split and twisted
2)O/S Arm bent
Driveshaft department...
1)Both front wheel bearings
Front Suspension department...
1)Both ball joints
Kindest Regards,
John
Last edited by Jon Boy UK - Wales on Wed May 19, 2010 6:36 pm, edited 1 time in total.
Transit 1995 MK5 ~ Series: 120 - SWB Hi-roof ~ Engine: Diesel 2.5 (70PS)
Jon Boy UK - Wales
Re: Next Job To Be Done
Postby MrMPuk » Wed May 19, 2010 6:28 pm
Wheel bearings and ball joints if they need doing would be first on the list.
Postby ME » Wed May 19, 2010 7:12 pm
All of the above :shock:
Mercedes Vimto Premium
ME
Postby Jon Boy UK - Wales » Sun May 23, 2010 12:17 pm
Hello,
Many thanks for your reply...
Due to my budget ( wife controlled ) i can only only have the mechanical things done to my waggon a bit at a time..
As i have to get everthing done by a garage as i'm not the best with a set of spanners etc in my hand.
I have the Transit Mk5 SWB - Hi-roof version... i would like it resprayed !
I live in cwmbran near newport south wales does anyone know where i can get the waggon resprayed to?. I have been to one place and they can only fit a sandard low roof tranny in.
Kindest Regards,
John
Jon Boy UK - Wales
Postby matthew2riches » Sun May 23, 2010 12:43 pm
Jon Boy UK - Wales wrote:Hello,
Kindest Regards,
John
Re painting: A few hundred quid in a back street boy's hand and he'll do it for you. I have the same prob round here - a lot of places can only fit people carrier or v-dub van size into their booth :(
matthew2riches
Postby WINDSCREENGUY » Sun May 23, 2010 1:10 pm
Not being funny but if you can't afford to get the important bits done(ball joints and wheel bearings) then how are you going to pay for a respray? (£1000-£2000)
formally grey van man.
WINDSCREENGUY
previously grey van man
Postby Jon Boy UK - Wales » Sun May 23, 2010 1:18 pm
Hello,
I just paid £165.00 inclusive for my center bearing/bush to be fixed/renewed in ford's.
Wasnt expecting it to be anywhere near the £1000 pound mark for a quick blow job / flash over ...lol ! ...
if that's the case then i'll paint it by hand with a tin of gloss for metal!
Kindest Regards,
John
Jon Boy UK - Wales
Postby MinorMatt » Sun May 23, 2010 1:44 pm
Dont go to ford! (£100/hr plus)
Go to an independant (£50/hr + )
Postby valeterjack » Sun May 23, 2010 3:50 pm
Kindest Regards,
John
try rustoleum it's better than gloss
http://www.rustoleumdirect.co.uk/
Imagemk5 nothing even comes close
www.scottish-vanners.co.uk
valeterjack
Postby doughythevanman » Sun May 23, 2010 5:30 pm
If you do the prep work yourself, i.e rust treatment, sanding, filling, rubbing down etc you should be able to get a blow over for around £200 - £300. It's a pity your not up here as the bloke in the local bodyshop does it for £200 inc paint if you do the prep. 8)
P reg SWB Semi high top
S reg LWB 190 Semi high top
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby WINDSCREENGUY » Sun May 23, 2010 6:55 pm
£200 must be a blind......ing job :lol:
WINDSCREENGUY
Postby doughythevanman » Sun May 23, 2010 7:29 pm
WINDSCREENGUY wrote:£200 must be a blind......ing job :lol:
Pretty decent job actually! :? As long as it's white!
Range Rover TD6
Volvo S80 D5
doughythevanman
Postby WINDSCREENGUY » Sun May 23, 2010 7:32 pm
standards must be low up northhhh lol as i was getting quotes of at least £1500 -£2000 :o
WINDSCREENGUY
Postby doughythevanman » Sun May 23, 2010 10:39 pm
For a full respray, with prep and looking mint then yes, you would be looking at around the £1500 mark but as i said if he does the prep work and just wants a good flash over to have the van looking right again then £200 and the bloke actually does do a good job and will advise on any dodgy prep work! :wink:
Range Rover TD6
Volvo S80 D5
doughythevanman
