hi i have a transit 2.4 rwd, pannel van 2004 reg 125 bhp 330 white.
what should be the cranking voltage read ? mine is 9.2 volts
bazw wrote:13.2 + i think![]()
what is it at rest ?
MrMPuk wrote:bazw wrote:13.2 + i think![]()
Something wrong if you're getting that while cranking!
SirKit Breaker wrote:What is the battery voltage when nothing is running? A good battery should be around 11.5 to 12.5 volts, this will rise to about 13 when charging.
If it is dropping to 9 volts when cranking it sounds like it has lost a cell, does it smell eggy, or does it give off steam when you try to crank it over? Is it getting hot. I would take the battery to a garage and get it discharge tested this will confirm if you have a good battery or not. Before getting into paying out any money check all the battery leads and connections including engine earth strap, if anything is even slightly amiss in this department then you will have no end of problems trying to turn the engine.
Cheers..........Howard
SirKit Breaker wrote:Not disagreeing with you MrM, as you are far more knowledgeable than me with transits. But its always worth a look at the basics before forking out any of the hard earned in my opinion.![]()
Cheers............Howard
Users browsing this forum: Bing [Bot], Majestic-12 [Bot]
