all dash lights gone off, van wont turn over 2001 t280 2.0di
Postby podrikk007 » Mon May 24, 2010 7:04 pm
turned key in ignition, dash lights came on, then went off for no reason. van wont start, wont turn over, iv got nothing. hazards and central locking works, but no radio, heaters, dash lights or starter. had to run a wire from battery to black box to get ignition and bump start it. tried a wire straight to starter while ignition was on but it wouldnt have it. anyone any ideas please???? thanks
podrikk007
Re: all dash lights gone off, van wont turn over 2001 t280 2
Postby mantav8 » Mon May 24, 2010 7:22 pm
Checked fuses?
mantav8
Cosworth Powered
Cosworth Powered
Postby podrikk007 » Mon May 24, 2010 7:33 pm
yeah all seem fine
podrikk007
Postby mantav8 » Mon May 24, 2010 7:38 pm
Where are you looking?-engine and dash?-best to test with a test light as fuses can look o.k but aren't, IIRC there is a Ignition relay on the dash fuse board,worth checking that too. :wink:
mantav8
Cosworth Powered
Cosworth Powered
Postby podrikk007 » Mon May 24, 2010 8:08 pm
u mean under the cover on top of passenger side dash?
podrikk007
Postby mantav8 » Mon May 24, 2010 8:09 pm
yup.
mantav8
Cosworth Powered
Cosworth Powered
Postby podrikk007 » Mon May 24, 2010 8:20 pm
thanks, will check
podrikk007
