Engine behaviour 2.5 Diesel
Postby mvdlans » Sat Jun 26, 2010 10:47 pm
Bonjour,
I have a MK5 2.5 diesel from 2000 with the old type of engine in it. And to me it's the strangest diesel I ever rode. It has got some power in the lower revs. Than in the middle mine has absolutely no power at all. And than, I guess at around 3000rpm she goes like a 'rocket'! Even in the hills, if you climb in low gear, she goes slower and slower and you have to downshift all the way. But when I play with the clutch, rev high, the motor picks up again and eventually speeds up the hill.
To me this occurs as a strange way of diesel behavior. Or do you guys share my experience?
Greetz,
Michiel
mvdlans
Re: Engine behaviour 2.5 Diesel
Postby Nadjenka » Sat Jun 26, 2010 11:04 pm
I was just saying the same thing today :o :lol: :lol: I don't call it extreme or unusual tho... My Lola is happiest at 73-74mph, just little bit over 3000rpm. At those revs she has loads of power to go faster on overtaking and doesn't mind any hills. However - if the revs drops below 2700 - 2500rpm, she will get "scared" at the slightest of hills, yet - below 1700rpm she has the power again :shock: Very strange, but also predictable and easy to work with if you have the rev counter :D I can't tell if this is unusual or not, I'm happy with what she can do 8)
Nadjenka
Postby Altransit » Sat Jun 26, 2010 11:05 pm
Sounds to me like the 'torque sleeve' inside the pump is sticking :?
Postby AndyG » Sat Jun 26, 2010 11:29 pm
It might just be the way the pump is set up to give you the best economy for cruising and yet still be able to deliver a punch when required :?:
Postby Nadjenka » Sat Jun 26, 2010 11:32 pm
Andyg wrote:It might just be the way the pump is set up to give you the best economy for cruising and yet still be able to deliver a punch when required :?:
That's what I'll go with :mrgreen: I'm happy with what she does and how she does it and how economical she is at the moment 8) 8)
Nadjenka
