by winterheating » Sun Jun 27, 2010 11:23 pm
you need to make sure original pump has not failed causing engine failure first, i would just leave engine complete and code pump in, when all fitted.
auto locksmith, or mobile mechanic should be able to sort it, or tow to a ford dealer or other garage....
as your van is xreg, the map sensor, intake temp, and egr connections will be different so you will need to fit your EGR valve and your engine loom to the replacement, also if you dont do this the new "engine loom" wont match up to your earlier engine bay loom.
you will have to change inlet manifold aswell i think.
