gordymack wrote:is it just me or is there a confusion about solenoid valve on our fuel pumps we have a timing solenoid valve which if defective should not leake fuel and and from ford costs around £75 then we have the metering solenoid valve which is more expensive and common to be source of fuel leaks and requires special tool to replace and can be as much as £300 not inc labour
gordymack wrote:hi can anyone advise me i have 05 plate fwd transit 2.0 ltr 125ps which is leaking diesel from the solenoid valve which i thought could be replaced but the garage i took it to has told me that ford have told them that the fuel pump on my van cannot have the solenoid valve replaced advising me that i will have to replace the entire fuel pump which is not at all a cheap option , i would be most gratefull if any one can advise me ,,
regards
gordy
