1998 speedo
1998 speedo
Postby Tasman » Sat Aug 28, 2010 3:19 pm
we have a 98 LWB. The speedo stopped working, looked in the haines but the van doesnt seem to have a speedo cable. Help
Tasman
Re: 1998 speedo
Postby Mikey B » Sat Aug 28, 2010 3:48 pm
First check fuse!!!
Could be the speed sensor on the box, the wiring or the speedo clock. More than likely be the speed sensor.
MKB Autos All makes and models catered for.
Mikey B
Ford Technician
Re: 1998 speedo
Postby Tasman » Sat Aug 28, 2010 4:04 pm
Thanks, checking it out now. Surprised there's nothing in the haines about it tho
Tasman
Re: 1998 speedo
Postby unclealec » Sat Aug 28, 2010 7:11 pm
I think Haynes do Mk 5 manuals that stop at about 1996, as well as the ones that go up to 2000. The electronic speedos didn't come out until about 1997? therefore not mentioned in the earlier edition of Haynes manual.
1997 Mk. 5 SWB 120 2.5di
Mk. I camper project
RM series Rileys
unclealec
Re: 1998 speedo
Postby kentgpz11 » Sat Aug 28, 2010 11:00 pm
My Haynes manual goes upto 1999 & I can't find anything about this either, other than it's on the gearbox.
The speedo doesn't work on our 2000 van either. :(
Image The 2 tone money pit.
kentgpz11
Re: 1998 speedo
Postby MrMPuk » Sat Aug 28, 2010 11:02 pm
That's because the Haynes manuals are sh*t!
Re: 1998 speedo
Postby kentgpz11 » Sun Sep 05, 2010 11:07 pm
Checked the TIS disc too, can't find much on there either.
Changed the speed sensor for a scrapyard one, checked the wiring & still nothing. :(
Maybe it was a duff one, who knows? :?
So back to square 1 again. :x
kentgpz11
Re: 1998 speedo
Postby Tinbasher » Fri Sep 10, 2010 12:21 am
Hello there. I've just joined this forum, so thanks a lot.
I have an issue with electric speedo too. I changed the gearbox 2 weeks ago. I had originally an electric speedo that worked fine. My gearbox lost both reverse and 5th gear (I'll ask about that later). I had the elctronic sensor (on the nearside rear of the box) and where a speedo cable would be was a blanking plug.
I got another gearbox from a scrapyard (60 quid) and noticed it has both the cable drive outlet (on the O/S) AND the electronic unit on the N/S. same as my old one. The lads had cracked the male end of the multi-plug that connects the unit to the wiring loom. No worries, I got the box back to work, and swapped the units as a first thing, only because my plug connector was better mainly. It was also a known working unit. I had to tilt both boxes on their sides when swapping the units, else all the oil comes out.
I've fitted the box and all the gears are fine, smooth, no noises. But no speedo working. i'm positive I've connected everything correctly. The problem now is that if I wish to swap back or replace with another (scrapyard?), I will lose the oil when I remove it. I'm not too bothered about that cos it is probably wise to replace it anyway and that has been my intention, but I don't want to do that and still not have a speedo working and then have to do it again.
I admit, I didn't know it was fused and haven't checked that, but if fuse is ok, what next?
The only differnce from my old set-up is that I now have an un-used cable drive peeping out of the box, whereas it used to be blanked off, but otherwise the electric sensor is fitted and connected exactly the same.
Tinbasher
