Timing belt tensioners
Postby wombatcurry » Mon Jul 24, 2006 10:35 pm
Couldn't find any mention of this on here, so for information:
Just changed the timing belt (because the water pump had gone & it looked like the belt had suffered).
On getting a kit from the motor factors, I found out that the tensioner in the kit was nothing like the one on the van - the guys in the shop couldnt explain why - their parts book definitely showed that the one they had was for my van (97 diesel).
Hunting around the internet, it turns out that since 2001 Ford recommend changing the tensioner - see http://www.catautomotive.co.uk/technical.shtml for pictures of the "old" & "new" types of tensioner - the Haynes manual doesnt mention this - if you've got the TIS it does (but you've got to look to find it) & describes how to tension the belt with the new tensioner.
wombatcurry
Postby Nighthawk » Mon Jul 24, 2006 11:48 pm
Yes, the old manual static type tensioner is no longer supplied as a service part, a new automatic tensioner replaced it.
It's real easy to do, just install the belt leaving the 4 bolts on the pump pulley loose, wind the tensioner round so the markings line up and then tighten everything up.
turn the engine 1 and 7/8 turns and recheck the markings, if ok your done...if it's tight re do the whole lot again.
Transit.........Job done
Nighthawk
Postby MrMPuk » Tue Jul 25, 2006 12:37 am
The old type were on a slider and the new type are on a roatary spring. Rotary spring is the only type to have TBH.
Welcome by the way!!!
Postby gemini » Tue Jul 25, 2006 12:52 am
new type
old type
gemini
Postby MrMPuk » Tue Jul 25, 2006 12:54 am
gemini wrote:new type
old type
Exactly!
Postby madmark » Tue Jul 25, 2006 3:55 am
mike is a dab hand at these! :lol: :lol:
Postby Luke » Tue Jul 25, 2006 12:24 pm
what is it about the new ones thats better :?:
Postby Nighthawk » Tue Jul 25, 2006 6:14 pm
it's contantly applying the correct tension to the belt, where as the old one could only apply the correct tension during initial setting.
with the old system the tensioner was unable to compensate for thermal changes within engine, wear and the whip on the belt when running.
If you run a 2.5 with the belt cover off and a new type tensioner fitted you'll see how much the tensioner moves when the engine is revved.
Nighthawk
Postby Luke » Tue Jul 25, 2006 6:24 pm
interesting :idea:
funny how it took 15 years to realsie the old one was no good :lol:
and top 1st post wombatcurry :D
Postby MrMPuk » Tue Jul 25, 2006 6:28 pm
I dunno exactly when Ford released it but I know the old one wont fit my engine as I don't have the holes for it.
