Manual to automatic conversion
Postby sim1964 » Fri Sep 03, 2010 9:23 pm
Hi all
Our Drag strip uses an early to mid 90's traansit 2.5 diesel (banana inlet engine) as a track drier using a ducted Rolls Royce Viper jet engine and as a manual it is damned hard to drive as slowly as necessary when drying the track.
We therefore wish to convert it to automatic box. What parts will we need?
Simon
sim1964
Re: Manual to automatic conversion
Postby AlanN » Fri Sep 03, 2010 9:34 pm
You could do with a donor van really, A4LD autobox with Di bellhousing, box mounts, selector, prop and engine bay loom.
Postby sim1964 » Sat Sep 04, 2010 8:25 am
Thanks.
sim1964
Postby AlanN » Sat Sep 04, 2010 8:54 am
You could get around the loom by fitting a relay between the inhibitor switch on the box and starter solenoid, to stop it starting in gear. Not too hard to do, plus the reversing lights come off the same switch, bullet connectors will sort that one
Postby AndyG » Wed Sep 08, 2010 10:57 pm
Or change the diff for a "towing ratio" and fit a wide ratio gearbox :idea:
Postby AlanN » Thu Sep 09, 2010 12:39 am
I was going to say, id be interested in seeing a picture of a diesel and jet powered Transit :wink:
Postby knighty1981 » Thu Sep 09, 2010 12:53 am
if it's only used for that.... and kept at the track.... stick some tiny tyres on the back instead... job done ;-)
knighty1981
Postby AlanN » Thu Sep 09, 2010 1:01 am
knighty1981 wrote:if it's only used for that.... and kept at the track.... stick some tiny tyres on the back instead... job done ;-)
Dont get it, hows that going to make it easier to drive slowly, Oh hand I get it :lol: :lol: :lol:
Postby sim1964 » Thu Sep 09, 2010 8:08 pm
Will take some photos next time I am at the track and thanks for all the answers.
sim1964
Postby AlanN » Fri Sep 10, 2010 12:28 am
Your welcome
