rust attack
rust attack
Postby bouncymat » Sat Sep 04, 2010 12:43 pm
hi
i am after a bit of advice.
this morning i started having a poke at the rusty patch on the sill under the sld.
i started with this...
and found this underneath...
what i found is much worse than i was expecting so i thought i'd ask the experts.
should i -
1. fill it paint it and deal with the problem properly next time it flares up?
2. cut section out and get someone to weld in a patch?
3. (not sure if this is possible) replace whole sill?
probably very simple questions for you guys but i am new to all this.
van is 55 mk6 swb
before you say anything - being a transit i knew that it would rust, i just thought i might get a couple more years before there were holes!
thanks
mat
bouncymat
Re: rust attack
Postby trigger » Sat Sep 04, 2010 12:53 pm
Depends on what you want to do and what you can afford, best would be replace the cill but you could cut out, weld a patch in and fill over, that's disgusting for a 55 reg van, they say on here about mk5's being rusty but i reckon mk6's will be even worse when they are as old as mk5's are now :shock: :shock: :shock:
Mk5 Transit the daddy
trigger
Re: rust attack
Postby bouncymat » Sat Sep 04, 2010 1:08 pm
well i want it to be as good as i can get it and i suppose that does of course mean replacing the whole area. maybe what i need to ask is how much its going to cost me to get someone to cut out an replace that section followed by where do i get the part from.
bouncymat
Re: rust attack
Postby ginsambo » Sat Sep 04, 2010 1:57 pm
If it were me and someone else was to fix it, and I was planning on replacing a whole panel I'd choose a smaller local garage or mobile welder and watch them every minute. One of my Mk5's was an ex hire vehicle and had the inevitable replacement front wing from a minor collision done at a major bodyworks company. When I got around to taking the said wing off years later as it was rusty I discovered the gits with the spot weld drills had gone through about another two panels and not given them any protection afterwards so that rust crept in between inner and outer A pillar which then turned out to be a major job, all because someone was lousy with the drills and when they made a mistake didn't bother to weld the hole up and prime it. :roll:
Time is money and with a new wing you'd never know it had been in an accident, but its what you can't see that counts, especially if its for keeping.
Buy yourself some cutting discs, a replacement panel and some spot weld drills. Make everything ready by aligning/cutting and grinding back to bright steel and you'll save yourself a packet as that is where the work is at. Welding is the easy part.
My Mk5 was biodegradable and disintegrated with time.
Ford. Committed to the Environment
Finally entered the 21st Century and bought a MK7. Oh Dear.
ginsambo
Re: rust attack
Postby scotty281976 » Sat Sep 04, 2010 9:33 pm
ive got mine rotten in the same place its about a foot long from the arch its a 03 ex rac. mk6/7's are deffo going to be worse than mk5@s. im going to cut it out and replace it them im getting rid of it and buying a spr*£ter :oops: new transits are shite they rust have timing chain probs and injection pump probs. i wish i bought the uber clean mk5 i could have had when i bought my mk6. you live and learn as they say
2011 mk7 ex rac 140t330 awd
scotty281976
Re: rust attack
Postby ginsambo » Sat Sep 04, 2010 11:38 pm
Take a Mk5 apart panel by panel and galvanise! Then put it all back together again. That's my plans, at least with the chassis and c members....Will never have to buy a pickup again! :lol:
ginsambo
Re: rust attack
Postby Brains_transit » Sun Sep 05, 2010 1:36 am
you can buy the sill part that goes the full length of the sliding door to the join about 2 inches back from the rear arch for around £70 at ford although i paid £55 when i went :lol:
Brains_transit
Re: rust attack
Postby bouncymat » Sun Sep 05, 2010 5:13 am
off to ford on monday then.
is it a tricky job to get old bit out?
bouncymat
Re: rust attack
Postby matthew2riches » Sun Sep 05, 2010 7:52 am
bouncymat wrote:off to ford on monday then.
Angle grinder and hammer usually works :wink:
matthew2riches
