Twin 50/50 Opening Tinted Glass Sunroof.
Postby Leeday » Fri Sep 10, 2010 4:42 pm
Bought this sunroof 2nd hand to go in my Transit... but after much thought decided to go a different route, so before I put it on E-Bay, I will put it up here incase anyone has a project on the go...
It is a 50/50 split glass sunroof .... can open either drivers side, passenger side or both.. or release all clips and glass can be removed completely.
Has an interior light built into the centre divide bar (wires are short and will need new wires soldered on).
I have made up a template if wanted.
I have also sprayed it with a hosepipe and the seals are waterproof.
There is no other fittings and so new owner will have to fabricate clamps to hold sunroof in place.....the sunroof frame has tapped holes all the way around on the inside (M4 or M5 I think) so 25mm x 25mm angle with holes drilled would easily work to clamp the sunroof in.
Hole cutout for sunroof to fit will be 975mm wide x 515mm deep.
Each glass panel is 485mm wide x 465mm deep.
Glass is PPG Saftey Solarcool Solid Tempered Coated DOT 18.
I paid £50.00 for it and so thats what I am asking for it .......spent hours cleaning it and had to drive around the world to collect it :lol:
1989 Mk3 swb, 3.0 V6 Essex, 5 Speed Manual: http://fordtransit.org/forum/viewtopic. ... 3&t=142054
2005 Mk6 2.0 Duratorq 100 T350 MWB Semi High
Leeday
Re: Twin 50/50 Opening Tinted Glass Sunroof.
Postby Leeday » Fri Sep 10, 2010 8:42 pm
Meant to say: I paid £50.00 for it and so thats what I am asking for it .....however I am open to offers :D or swaps :D .
Looking for wheel spacers (pair for the rear axle, set of alloys, twin choke weber carb for 2.0 Pinto + inlet manifold for the same or any other interesting parts for my Mk3 Transit...let me know if you have any bits and maybe we can sort out a deal.... cheers
Leeday
Postby Leeday » Fri Sep 24, 2010 8:11 pm
Still got this sunroof...
£20.00 if anyone wants it (collect) or £35.00 (posted)
Still looking for a pair of wheel spacers, weber carb - Inlet manifold ... or even a 2.0 DOHC head (carb version).....
Leeday
Postby Leeday » Fri Sep 24, 2010 9:46 pm
Sunroof now sold.............
........Still looking for a pair of wheel spacers, weber carb - Inlet manifold ... or even a 2.0 DOHC head (carb version).....
Leeday
