mondeo clocks in mk3....
Postby apples26 » Fri Jul 28, 2006 10:48 pm
ok got me clocks thanks to guy88 ;)
will fit em next week has anyone had any probs fitting as per the thread in technical how too's?
im also thinking more along the lines of trying to tidy up the install a little more so it looks more factory so to speak
any ideas? im presuming i may get the black dash surround bit around the clocks froma mk5 and try some cutting/filling etc to mate it to the mk3 one
anyone any pics?
apples26
Postby Guy88 » Sat Jul 29, 2006 12:09 am
Mine fitted OK :lol: :lol:
Im going to have a play with the surrount tomorrov and see what happens :D
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby apples26 » Sun Jul 30, 2006 7:22 pm
did you have any incorrect guage readings?
also on the how to section it says theres 3 wires left in the original plug do you just blank them off ?
on the mondeo cluster i have it has the large plug the smaller plug, theres also a smaller plug socket more of a square not even an inch in diameter, do i need to not worry bout that?
apples26
Postby Guy88 » Sun Jul 30, 2006 7:49 pm
The speedo on mine is about 5MPH out and the fuel guage is out. also i need to get a mondeo temp sender as the transit and mondeo ones have different resistance
I havent got the plug so just ignore it. you can either blank off the wires or leave them. there all inputs so no voltage. i also wired up the low brake fluid sensor onto the ABS warning and fitted a handbrake warning on the other light 8) the little plug i believe is where the airbag controller plugs in. If you want to have some fun fit a switch to turn the sports mode light on and say its for the nos :P :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sun Jul 30, 2006 9:38 pm
Where's this 'sports' light exactly :?:
I wouldn't mind one of those :!: 8) 8) 8)
Is it hiding in my MK5 clocks somewhere :?:
Postby Guy88 » Sun Jul 30, 2006 10:13 pm
On the mondeo ones its one of the ones in the bottom row. think its on the right and its green. when me new clocks arrive il know for sure.
Iv seen these clocks fitted to mk5's and the sports light is always on. most people take the bulb out :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sun Jul 30, 2006 10:15 pm
I think it's time for the torch :!: :lol:
Infact I'll go out now and have a look :D
Postby Guy88 » Sun Jul 30, 2006 10:17 pm
what have i started now :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Guy88 » Sun Jul 30, 2006 10:18 pm
What i can tell you is that if you put 12v to the small plug pin 9 on a set of mondeo clocks it puts the sports light on 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sun Jul 30, 2006 10:21 pm
:( :( :( :( No sports light :( :( :( :(
Guy88 wrote:what have i started now :roll:
A light that makes the van a bit faster :!: :lol: :lol: :lol: :lol:
Postby Guy88 » Sun Jul 30, 2006 10:23 pm
Wat about the ABS, Active suspention, Auto and all the other random lighhts you could have in a mondeo
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sun Jul 30, 2006 10:27 pm
Not suprised some of them don't work in Transits :shock: :lol: :lol: :lol:
Any more lights :?:
Postby Guy88 » Sun Jul 30, 2006 11:03 pm
Lights that are not used on mine are
Next to charge light is speed limiter light
Bottom L/H Airbag, Wheel slip, low oil level, ECU error
Bottom R/H Active Suspention, Sports mode, O/D on.
Above oil pressure light is the ABS warning
Lots to choose from :shock:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby AndyG » Sun Jul 30, 2006 11:25 pm
Well I've got an ABS light and my airbag light is being used as one of my alarm lights :wink:
Your 'speed limiter' must be cruise control 8) 8) 8)
But I could do with the 'sports' and 'O/D' light :D :idea: 8)
