Partial Alternator Warning light
Postby Badgervan » Mon Sep 20, 2010 5:15 pm
Hi all,
My 88, 2.5Di, Mk3 has started showing a partially lit alternator warning light after the usual blip of throttle to extinguish the light (ie switch from battery to alt running voltage)
The alt is dumping out 14v the batteries are charging and the electrics are all running fine,are there any common causes of this fault?
D
Badgervan
Re: Partial Alternator Warning light
Postby fortyeight » Mon Sep 20, 2010 5:58 pm
hi my warning light stays on a while been told its delayed action from split charger
fortyeight
Postby Badgervan » Mon Sep 20, 2010 7:00 pm
fortyeight wrote:hi my warning light stays on a while been told its delayed action from split charger
mine ain't stayin on full brightness on it's only very dimly lit
Badgervan
Postby Altransit » Mon Sep 20, 2010 7:35 pm
It's a fault with one of the diodes in the diode pack leaking back voltage :( So long as it's charging OK, you could ignore it, but if it bothers you, then change the alternator :wink:
Postby ake » Tue Sep 21, 2010 6:55 am
The problem is that it may start to discharge the battery when the van is sitting switched off
Postby fortyeight » Fri Oct 01, 2010 2:47 pm
have you got an alarm on
fortyeight
Postby solarman » Fri Oct 01, 2010 11:07 pm
Sorry to but in but was wondering what is causing a low charging reading on my van's alternator?The other day i measured my battery and it was showing12.1 volt not running,today i decided to measure the voltage on battery while engine was running and i was gettingb a reading of 12.3,12.4 slowly rising,but i was expecting a reading of 14 .4 ish as an alternator
would be charging at about that voltage,it has been starting okay but i will need to sort it out as it is undercharging as far as i'm concerned,
Solarman.
Forgot to mention thbat i don't hbave an alternator light lit on dashboard which is unusual if it's not chbarging properly.
solarman
Postby ake » Sat Oct 02, 2010 8:46 am
solarman wrote:Sorry to but in but was wondering what is causing a low charging reading on my van's alternator?The other day i measured my battery and it was showing12.1 volt not running,today i decided to measure the voltage on battery while engine was running and i was gettingb a reading of 12.3,12.4 slowly rising,but i was expecting a reading of 14 .4 ish as an alternator
Solarman.
How accurate is the voltmeter you are using :?:
Postby Jim Archer » Sat Oct 02, 2010 8:55 am
And how lok after starting it did you do the check, almost imediately? or after a good run?
If straight after starting it, it takes a while for the alternator to bring the battery back up to fully charged.
Jim
Mk7 140 Jumbo - Vantunered.
289,000 and counting.
Jim Archer
Postby solarman » Sat Oct 02, 2010 8:56 pm
It's a multimeter and yes only checked it while engine is running,will do another check after a long drive see if it makes a difference,thanks,
Solarman
solarman
Postby ake » Sat Oct 02, 2010 9:33 pm
solarman wrote:It's a multimeter and yes only checked it while engine is running,will do another check after a long drive see if it makes a difference,thanks,
Solarman
Do you have acces to another vehicle that you could check your multimeter on and then you would have readings to compare with
Postby solarman » Sat Oct 02, 2010 9:46 pm
Solarman
could check a mate's LDV diesel tomorrow at same time and report my findings,thanks.
solarman
Postby solarman » Sun Oct 03, 2010 10:07 pm
well i went to my mates measured his(two batteries in parallel set up) they measured 13.4 volts,switched his engine on charging at 14.4 volts.Measured mine not running 12.3 volts,switched engine on voltage rose slowly again 12.3,12.4,12.5.
Checked altenator belt seemed a bit slack,so we adjusted for belt tightness,measured again while running and a big improvement charging at 13.87 and stopping around the 13.90.I'm happy with this for now,but i'm wondering if there is a voltage diode to stop it charging more than 13.90 or is the alternator still not charging at max voltage?Even with revving the engine it wouldn't charge higher than 13.90 any ideas?
Solarman
solarman
Postby fortyeight » Mon Oct 11, 2010 1:44 pm
does the fan belt look worn shiny if so it could still be slipping a bit, or the pully a bit worn, grooved extra shiny would course it to slip
fortyeight
Postby solarman » Mon Oct 11, 2010 2:15 pm
The old fan belt has snapped so i've replaced it for new and the power steering belt at same time,battery appears to be charging well now and reaching 14 volts,
Solarman.
solarman
