battery and tray
battery and tray
Postby solarman » Fri Oct 01, 2010 1:11 am
A couple of questions,i need a new battery to replace my starter battery for a 2.5 non turbo,what size in amps or CCA?
Also i intend to back up the new battery with the older battery wired in parallel for starting use only,so i will need a battery tray fitted on the opposite side,what is the best way to fit one and where can i get a battery tray from?
Solarman.
solarman
Re: battery and tray
Postby Timbo » Fri Oct 01, 2010 11:45 am
You need the battery tray from a petrol van as this goes on the left side inner wing. Try breakers or e-bay.
Timbo
Postby sailorman » Sat Oct 02, 2010 5:26 pm
HI,
If its any help my battery is 70 amps 2.5 non turbo desiel. with a secound 70amp fully charged but not connected on secound tray right side.No starting problems.
Sailorman.
sailorman
Postby MinorMatt » Sat Oct 02, 2010 10:18 pm
The starter battery will be an 096 if its got round terminals.
Ideally you should be looking at a CCA of 650A or more
Postby solarman » Thu Oct 07, 2010 8:46 pm
MinorMatt wrote:The starter battery will be an 096 if its got round terminals.
mine has round terminals but has CCA of 550 marked on the battery.I suppose a larger CCA would be better anyway so i will
get the next size up.Any ideas on a battery tray,fabrication or salvaged and how to fix in place would be appreciacted thanks,
Solarman.
solarman
Postby MrMPuk » Thu Oct 07, 2010 8:50 pm
Solarman.
You've got the wrong battery then.
viewtopic.php?f=4&t=53686
Postby Altransit » Thu Oct 07, 2010 8:53 pm
550 cca is a bit small for a Di, the 650 is the correct size, or you can now get a 750 which is the same physical size as the 650. I've just fitted one of those 750's in to mine ready for the winter 8) :wink:
The petrol van battery tray simply bolts in to the other side, using threaded holes which are already there :D
Postby MinorMatt » Thu Oct 07, 2010 9:04 pm
The 096s in my van are not as much as 650 CCA (I cant remember what they are without looking) - but I do have 2 of them
Postby MrMPuk » Thu Oct 07, 2010 9:08 pm
590cca is standard as I said in the link above.
Postby solarman » Thu Oct 07, 2010 9:22 pm
i was thinking it was a bit small but it was already on the van when i bought it,i will be putting a bigger one on soon,may just wire this in parallel with the new one for backup,
Solarman
solarman
