Mk3 Propshaft to gearbox question.
Postby vana mana » Mon Oct 11, 2010 10:05 am
Can any one tell me ?
Is there only 1 type of thread in the gearbox plate that connects via bolts to the propshaft..
or another way of putting it.....
is there only 1 type of threaded bolt that connect the propshaft to gearbox ???
or is there different types...
Its a MT 75 gearbox...
vana mana
Re: Mk3 Propshaft to gearbox question.
Postby MrMPuk » Mon Oct 11, 2010 10:11 am
viewtopic.php?f=2&t=74679&p=632915#p632915
How many threads are the bolts going in before they go tight? When you take them out are there any shiny bits on the threads?
Postby vana mana » Mon Oct 11, 2010 12:07 pm
MrMPuk wrote:http://fordtransit.org/forum/viewtopic.php?f=2&t=74679&p=632915#p632915
Thank you for pointing out that i have a thread going very similar...but i have not had much response from that thread...so started a new thread aboult bolt thread sizes...
im not sure if its because the gearbox bolt threads are rusty ?..i have cleaned then internaly a little using a dremmel with a fine brush and removed the thread seal / blue stuff from one bolt and that perticular bolt has gone in further.....
But i do not want to tighten up and sheer off :(
The bolts im using came off a petrol engined vehicle with a MT 75 gearbox H / Reg..im not using this gearbox though..im using one that i think is better condition from a previous petrol engine gearbox combination that came with no bolts :(
The threads on the bolts i am using are only going in upto the blue stuff...im not sure what im looking for but yes the threads seem to be a bit shiny...
vana mana
Postby MrMPuk » Mon Oct 11, 2010 12:09 pm
So how many threads are they going in before going tight? When you take them out are there any shiny bits on the threads?
Postby vana mana » Mon Oct 11, 2010 12:37 pm
MrMPuk wrote:So how many threads are they going in before going tight? When you take them out are there any shiny bits on the threads?
sorry ..about 4 threads..up to blue stuff ..the threads on bolts look shiny..but cant really notice much diffrence...
just took the bolts..1 without blue stuff and 1 with blue stuff and tried em in original box they came out off..the 1 with blue stuff got tight around the blue stuff entering the gearbox end the 1 without went straight through...i tried em both in the threaded gearbox end where 2 out of the six bolt holes wernt used /rusty similar results to the gearbox im trying to use em on...
i think..when i cleaned threads with dremmel..i could only get three quaters way along andreckon the rust at the other quater is stiffening things up??
vana mana
