Camper Conversion using recyled materials.
Postby dirtydiesel » Thu Oct 14, 2010 7:33 pm
Hello all.
I bought an automatic 1996 lwb hr turbo diesel transit in January 2010. I'm in Ireland, the van was for sale in dingle Co.Kerry for 100euro. It was on UK plates(p) and had been parked up for 2 years. The guy who owned it moved here from the UK and used it to move his stuff over, then parked it up.
Drove the 80 miles to dingle with a friend, brought 2 batteries, drum of diesel,sledge hammer and oil. we fitted the batteries and topped up the oil and water and threw in a drum of diesel, turned the key and it started straight away! GO ON THE TRANSIT.
Few taps of the sledge and all the brakes were free.
The guy had receipts for various work done to the van including a recon box. Paid him and we were off on our merry way on some bad coast roads, plenty of steep hills and sharp bends, gearbox was a bit slow to change down so ended up doing it manually. got to within 30 miles of home when she cut out, stopped dead on a bend on a bad road, oh shite, Turned key and she started and ran enough to get her off the road, popped the bonnet to have a look, and the lovely dry engine I saw in Kerry was covered in oil, Took a me sort of while to find the problem, it was a crack in the oil filter, left the van and went to get one, but to no avail, a local garage gave us a drum of waste oil and sort of paste(cant think what it was called) patched the filter and filled her with waste oil(had no cash to buy new oil). Said a prayer as I turned the key, oh yes she started.
Off we go paranoia setting in now so I'm stopping every few miles, loads of oil dripping off engine but the filter holds up.
Get home park her in the driveway and switch her off, feeling relieved to get her home.Grabbed some old carpet and put it under her to soak up the oil dripping off underneath.
After tea and sandwiches went to start her only to hear a loud click, try again click and again click, its in park, has loads of oil, and 2 good batteries, still it just clicks, I'm sickened as its gotta be seized, thinking why did I put waste oil in it.
Went to the pub to drown the sorrows, very hung over on Sunday morning I turn the key and she starts, oh yes I'm a happy man.
Bought new oil and a filter on Monday and ordered brake pads and other bits, done all that and she has been running sweet ever since.
Used her to deliver bouncy castles all summer and decided to turn her into a camper this month.
Got some seating and bits and bobs from a scrapped mobile home(all for free) gathered up scrap bits of timber from building sites.
Water damaged flooring given to me for free.Image
Started to cut a panel in bulkhead, grinder died! fitted tv stand and you can see a single bed Ive fitted.Image
bed on topImage
U shaped seating which opens out into a double bed, salvaged from a mobile home, shelving and speakers fitted.Image
NOW YOUR SUCKING DIESEL.
dirtydiesel
Re: Camper Conversion using recyled materials.
Postby rover » Thu Oct 14, 2010 8:34 pm
What a bargain!!! 8)
rover
Postby dirtydiesel » Thu Oct 14, 2010 8:36 pm
Sure was, not many auto transits this side of the water, its a pleasure to drive.
dirtydiesel
Postby Nadjenka » Thu Oct 14, 2010 8:45 pm
AND it's GREEEEEN :mrgreen: :mrgreen: Bargain and it put a smile on my face, like it :!: 8) Keep the pictures coming :D
Nadjenka
Postby dirtydiesel » Thu Oct 14, 2010 8:51 pm
Nadjenka wrote:AND it's GREEEEEN :mrgreen: :mrgreen: Bargain and it put a smile on my face, like it :!: 8) Keep the pictures coming :D
its not going to be green for much longer :D , im doing the bodywork and its getting a few coats of rustolem(dark blue) sign writing is staying on so loads of masking to be done, I have to get the paint in the Uk as cant seem to find it anywhere over here, so if anyone can point me towards a Uk supplier that would be nice.
Ive more photos but for some reason im not able to edit or add to my post :|
dirtydiesel
Postby Nadjenka » Thu Oct 14, 2010 8:58 pm
aaaww, just as I thought you'll be another member of the green crew :lol: :lol:
Just make a new post with more pictures :wink:
I order my Rustoleum from HERE, but don't know if they deliver to Ireland :(
Nadjenka
Postby dirtydiesel » Thu Oct 14, 2010 9:01 pm
She is a well known van over here, the green godess is her nickname, sound for the link, just had a look at your green transit, would of thought there is loads of Murphys green transits over there,
dirtydiesel
Postby dirtydiesel » Thu Oct 14, 2010 9:04 pm
Started stripping the cab to get at the rust on the floor, not too bad only surface rust, wish I could say the same about the stepImage
dirtydiesel
Postby imustloverust » Thu Oct 14, 2010 10:07 pm
You could try here for Rustoleum. It's called combicolour by made by rustoleum.
http://www.paintshop.ie/Steel-Protection/CombiColor---primer-and-topcoat.aspx
There's even a link to the VW lads who did their van in rustoleum.
imustloverust
Postby dirtydiesel » Thu Oct 14, 2010 10:19 pm
imustloverust wrote:You could try here for Rustoleum. It's called combicolour by made by rustoleum.
Sound for that link, I can get it from them, it was going to cost more for postage than the paint to get it from the uk.
dirtydiesel
Postby dirtydiesel » Fri Oct 15, 2010 11:21 am
Passenger side wheel arch which I thought was a small bit rusty until I got the hammer outImage
Ordered paint today, thanks to Imustloverust for the link, loads of prep to do on the body now.
dirtydiesel
Postby transitandy » Fri Oct 15, 2010 2:57 pm
good work so far m8y :)
Postby gravelrash2004 » Fri Oct 15, 2010 6:00 pm
i know the pain of rust :) looking good so far
My Projects
150S :- DOHC 2.0 EFI (115PS), Ratio: 5.14
viewtopic.php?f=27&t=66682&start=15
viewtopic.php?f=27&t=97579&p=829640#p829640
gravelrash2004
Postby dirtydiesel » Fri Oct 15, 2010 9:07 pm
What is it about transits? I'm well and truly hooked on mine, so much so the missus is jealous, says i give the green godess more atttention :mrgreen:
dirtydiesel
Postby dirtydiesel » Sat Oct 16, 2010 4:01 pm
My friend stella, whose been a great help so far
.Image
Ushaped seating tidied up using brown throws cut and stuck to the timber underneath
Panel cut out of bulkhead, just need to smooth it out with the grinder
dirtydiesel
