ignition coil keeps blowing
Postby mightyeel » Wed Aug 02, 2006 11:13 pm
HELP!!!!!!!!!!!!!!!!
HI FROM CANBERRA AUST
can any body help me with my 2001 transit i recently purchased.
it keeps blowing the same ignition coil!!!!!
any of u transit heads come across this?
i cany find any body in oz who can help.
cheers
mightyeel
mightyeel
Postby MrMPuk » Wed Aug 02, 2006 11:20 pm
Welcome.
Postby motorwise » Wed Aug 02, 2006 11:40 pm
does it kill the coil straight away or does it take a while?
http://www.motorwise.net
motorwise
ignition coil
Postby mightyeel » Wed Aug 02, 2006 11:48 pm
hi motorwise,thanks for the reply
the first lasted 2 weeks the second 3 months the third 2 DAYS!!!
mightyeel
Postby Nighthawk » Thu Aug 03, 2006 6:17 pm
Is this an LPG equipped vehicle?
Have you had the plugs checked?
The coils fail because of the excessive current being generated.
Transit.........Job done
Nighthawk
Postby motorwise » Thu Aug 03, 2006 9:08 pm
as said check the plugs first - a wide gap will over drive the coil as will a weak mixture - is it the same cylinder every time?
motorwise
ignition coil
Postby mightyeel » Thu Aug 03, 2006 10:29 pm
hi motorwise
yes its always the same cylinder.
its running on unleaded
cheers mightyeel
mightyeel
Re: ignition coil
Postby motorwise » Thu Aug 03, 2006 10:30 pm
mightyeel wrote:hi motorwise
cheers mightyeel
is the plug OK?
motorwise
ignition coil
Postby mightyeel » Thu Aug 03, 2006 10:37 pm
not only is it the same coil its also the same cylinder.
just before it blows the engine runs better
(more power)
cheers mightyeel
mightyeel
Postby MrMPuk » Thu Aug 03, 2006 10:37 pm
But have you checked the plug?
ignition coil
Postby mightyeel » Thu Aug 03, 2006 10:41 pm
they claim to have fitted genuine plugs as recommended by a ford mechanic in oz
mightyeel
ignition coil
Postby mightyeel » Thu Aug 03, 2006 10:46 pm
thanks MrMPuk,Nighthawk,Motorwise!
ill get them to change the plugs AGAIN
great forum!
ill let you guys know how i get on
THANKYOU
mightyeel
mightyeel
Postby motorwise » Thu Aug 03, 2006 10:54 pm
check the colour of the plugs as well - in particular uif that plug is a different colour - a weak mixture will cause the firing voltage to rise so you need to find out if that cylinder is running weaker than the other three
motorwise
Postby Nighthawk » Thu Aug 03, 2006 11:15 pm
If a coil has gone down, it'll affect 2 cylinders, so be sure to check both the plugs fed from the bad coil.
I'd check the lead too, if it wasn't replaced first time round change it now.
Nighthawk
Postby motorwise » Thu Aug 03, 2006 11:43 pm
Nighthawk wrote:If a coil has gone down, it'll affect 2 cylinders, so be sure to check both the plugs fed from the bad coil.
one half of a double ended coil can go down on it's own (happens to fiats a lot) - whats the set up on these then - is it like the galaxy?
if it is - is it the plug the coil sits on or the one attached to the lead thats going down - as nighthawk said if it's the lead side then the lead could be causing it
another thing to check (will need checking with a 'scope though) is the trigger signal to the double ended coil thats failing
I don't see any petrol transits all the firms I deal with have diesels
motorwise
Users browsing this forum: Transit Paul
