2.0 pinto 205 engine, box, prop everything
Postby chris_gilly » Tue Oct 05, 2010 10:18 pm
as above really, 89k running spot on, recently serviced, new cam belt, alt belt, alternator, dizzy, coil pack ht leads lift pump everything still on it, can be dropped straight in,
5 speed box top left reverse, prop etc
looking for £150 collected ch41 2qq
cheers
chris_gilly
Re: 2.0 pinto 205 engine, box, prop everything
Postby uib231 » Sat Oct 23, 2010 3:04 pm
Hello-ive got a 92 lwb minibus with a poorly engine-2.0 petrol with carb-is this the same.Apologies i am new to Transits !
cheers
uib231
Postby rover » Sat Oct 23, 2010 6:41 pm
It will be the same engine if its on carb's :wink:
rover
Postby darkbluevanman » Sat Oct 23, 2010 10:26 pm
rover wrote:It will be the same engine if its on carb's :wink:
Could still use if was injection pinto, just stick his carb on :)
darkbluevanman
Postby rover » Sun Oct 24, 2010 11:08 am
That wasnt the point I was making, on a 92 it's just possible to have had a DOHC, which was never on carb's in the Transit, but uib231 mentioned his poorly vehicle had a carb so therefor it must be a Pinto :wink:
I should've just said Yes in the first place :lol:
rover
cron
