Diff gears
Diff gears
Postby VooDoo » Sat Oct 30, 2010 3:28 pm
I am currently in the process of fitting a 9" diff into my mk5 transit which has six stud wheels so that I have an unlimited choice of ratios. I am using the transit outer tubes, axles and hubs and fitting a 9" housing. The 9" diff itself needs the axle gears changed to the Transit ones to accept the Transit axles. The problem is the only way I have of obtaining these gears is to buy the complete rear axle assembly from a wrecker, which is quite expensive here in OZ. Does anybody have a set of these gears out of a diff or know where I can get some?
Also can anybody tell me if there was a inner panel covering the front side of the tail lights on this model, and if so are they available?
VooDoo
Re: Diff gears
Postby MinorMatt » Sat Oct 30, 2010 7:43 pm
Which gears are you refering too? Im about to rip a diff out of a 6 studder... (well when I get round to it anyhow! :lol:
Re: Diff gears
Postby VooDoo » Sun Oct 31, 2010 1:38 am
The gears I'm after are the gears that the axles plug into.
VooDoo
Re: Diff gears
Postby misty12 » Sun Oct 31, 2010 9:21 am
gelong diffs make side gears to suit 9 inch
misty12
Re: Diff gears
Postby VooDoo » Sun Oct 31, 2010 10:59 am
I'll give them a call, however I have priced them from another company and they quoted $40.00 more than I payed for a complete rear axle assembly.
VooDoo
Re: Diff gears
Postby Terry » Mon Nov 01, 2010 6:30 pm
I reckon he will mean the 2 planet gears that the half shaft splines slide into. Saying that I have no idea if they are interchange-able. I would have thought not but I'm no expert.
Have fun
Pallet Puller
Terry
Re: Diff gears
Postby jrmr500 » Thu Feb 24, 2011 1:09 am
Hi VooDOo,
How did you go with changing the diff in the Transit? Im interested to know as I like the idea of this conversion. I am in Aus also, and 1200 for a replacement diff.... id rather go with a 9"....
jrmr500
Re: Diff gears
Postby Hydraulic Bloke » Fri Feb 25, 2011 12:46 pm
Hi Voodo, I'm currently swapping my 6 stud for an F100 9" drum to drum with a 3.5 ratio, measures up to 30mm narrower, however am redrilling axles to nissan 4x4 which gives a wide range of wheels and offsets, also f100 brakes are simpler and bigger. So will have a 6 stud diff d 2 d to give away. Cheers, Oh by the way got rid of that crappy 2.5 di also
You can go as fast as you want on a push bike
Hydraulic Bloke
