Newbie owner - loads of questions - Help!
Postby transitdude » Sat Aug 05, 2006 9:57 pm
Hello All,
Picked up my new van today (second hand) 2003 - 100 T260. Seems to be in good condition all round and at a reasonable price.
I want to do a service on the van as the last one documented was about 20k miles ago :shock: - but that said it does appear to run well with 51k on the clock.
Since there is no owners manual with the van I need to ask some general questions which I hpoe some of you can assist:
1) Where's the Engine number located?
2) Where's the VIN number (not the one stuck on the dash)
3) How much engine oil does this engine take?
4) What type of specification oil should I use?
5) How do I change the engine anti-freeze - is there a set procedure?
6) What is the significance of the 'press to reset' coloured valves which are positioned on the airbox and fuel filter?
7) Has anyone got a soft copy of the maintenance manual for this van?
8a) Is there anything else I should look into changing with the mileage currently on the van?
Frank
transitdude
Re: Newbie owner - loads of questions - Help!
Postby Nighthawk » Sat Aug 05, 2006 10:23 pm
On the side of the engine obscured by the turbocharger
on the sticker on the B pillar and also stamped into the body inside the O/S front wheel well...look near the O/S strut and you'll see it
about 6.5Lts
5W30 semi synthetic
empty the old coolant into a suitable container and refill with a 50/50 mix of new coolant slowly, they usually self bleed ok
they are filter condition minders, ignore the one on the air filter box as it never worked and has since been deleted, new filter every 30K
buy a hooky TIS disc off ebay
not really unless something needs changing.
hope that helps
BTw, welcome to the site. 8)
Transit.........Job done
Nighthawk
Postby MrMPuk » Sat Aug 05, 2006 10:39 pm
Welcome
Postby transitdude » Sat Aug 05, 2006 10:50 pm
Cheers Fella, and thanks for the replies.
Just to elaborate on some previous answered questions:
I bought some 10W40 Diesel oil which says it's suitable for all turbo engines and cars and light vans.... do you reckon I can get away with this in this engine?
Is there a engine anti-freeze plug somewhere to release the fluid or do I just pull a hose off?
Do you need to change the timing belt or cam chain on this engine or is it a chain that lasts forever..
Frank
transitdude
Postby Nighthawk » Sat Aug 05, 2006 10:58 pm
i'd take the oil back tbh and get the 5W30 semi synth, that was what the engine was designed to run on.
The hydraulic tappets and cam chain tensioner will thank you for it.
Yup, pull off a hose from the lowest point or just undo the drain plug on the radiator. there is also a bung in the engine block. it's on the turbo side of the block between cyls 3+4
but tbh, you'll be alright with pulling a hose.
the timing chain was designed as a fit and forget item......but some of the tensioners have given problems which has lead onto the failure of the cylinder head :eek:
still want to take a chance on the oil viscosity?
Nighthawk
Postby transitdude » Mon Aug 07, 2006 5:42 pm
Okay, wheres the best place to buy 6/7 ltrs of 5w30 diesel oil from? Does brand matter? Halfrauds charge about £45 for 4litres of Castrol stuff!!
:shock:
Frank
transitdude
Postby MrMPuk » Mon Aug 07, 2006 5:44 pm
5w/30 semi from a motorfactor like PartCo or whatever you have locally.
Postby gemini » Mon Aug 07, 2006 5:54 pm
go here on the left click on where can i buy
gemini
Postby transitdude » Tue Aug 08, 2006 8:09 pm
Okay, sorted. Got hold of some 5W30 Semi Grade oil from UniPart (they recommend as they use in their vans). Weird how it says it can be used in both Diesel and Petrol! :roll:
Anyhow, jobs a gooden, shall change it this weekend and all should be go.
Frank
transitdude
