MK6 knocking and white smoke
Postby Guy88 » Fri Nov 05, 2010 9:35 pm
Been out (in the rain) to look at a fellow members MK6 120 T350 2.4
Basically parked it up, left it the day, whent to start it, was very sluggish to start, has got a knock, no power, wont rev, LOADS of white diesel smoke
Theres no bubbles in the header tank
No glow plug light on,
Does this sound like a timing solenoid, injector or something more serious?
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Re: MK6 knocking and white smoke
Postby stu0500 » Fri Nov 05, 2010 10:01 pm
sounds like head gasket to me.
2012 vivaro 2.0 CDTI 140 bhp sortimo racking elec pack
2016 Transit custom Limited 155 ordered (with toys)
2013 Audi S4 B8.5 pearl black
2015 seat Leon FR 184 TDI Pearl black
stu0500
Postby winterheating » Fri Nov 05, 2010 10:04 pm
Sounds exactly like a fuel pump breaking down, swarf getting into injectors causing fuel not to atomize correctly, if left will just put a hole in a piston.
check fuel in the filter for swarf.
winterheating
Postby Guy88 » Fri Nov 05, 2010 10:05 pm
stu0500 wrote:sounds like head gasket to me.
Its smoke not steam, no bubbles in header tank, no gunge on oil cap, no pipes blowing up
winterheating wrote:Sounds exactly like a fuel pump breaking down, swarf getting into injectors causing fuel not to atomize correctly, if left will just put a hole in a piston.
its apparenly had a pump not so long ago :?
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby winterheating » Fri Nov 05, 2010 10:07 pm
What was wrong with the pump :?: :idea: :?:
IF it had broke down then tank should have been removed cleaned, new filter and check/replaced injectors otherwise the swarf would contaminate new pump and injectors. :(
winterheating
Postby stu0500 » Fri Nov 05, 2010 10:32 pm
I came across a 2.4 which was doing the same thing.wasnt bubbling, ran like a pig, lack of power, excess noise. turned out head gasket failed between the oil and cylinders.
stu0500
Postby Mikey B » Fri Nov 05, 2010 10:32 pm
Rocker shaft bolts lose? after the timing jumping?
MKB Autos All makes and models catered for.
Mikey B
Ford Technician
Postby winterheating » Fri Nov 05, 2010 10:37 pm
stu0500 wrote:I came across a 2.4 which was doing the same thing.wasnt bubbling, ran like a pig, lack of power, excess noise. turned out head gasket failed between the oil and cylinders.
Never seen or heard of a genuine Head gasket fault with a duratorque engine, very uncommon.
seen a cracked head though between inlet ports.
winterheating
Postby Guy88 » Fri Nov 05, 2010 11:19 pm
Mikey B wrote:Rocker shaft bolts lose? after the timing jumping?
will defo check that, im thinking of running it and cracking the injector pipes one at a time and see what makes a difference
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
