wheel adapters
wheel adapters
Postby turbotom395 » Wed Nov 03, 2010 7:10 pm
hi guys ive owned my transit for almost a year now its a mk6 and im going to start doing bits and bobs to it.
my question is does any one know if i can get some adapters made to fit some diffrent alloy wheels
thanks tom
turbotom395
Re: wheel adapters
Postby MrMPuk » Wed Nov 03, 2010 7:24 pm
Yes you can.
Re: wheel adapters
Postby ripbuster » Wed Nov 03, 2010 7:27 pm
ripbuster
Re: wheel adapters
Postby turbotom395 » Wed Nov 03, 2010 9:28 pm
thanks guys, now what sort of size alloys do you think would look good
turbotom395
Re: wheel adapters
Postby MrMPuk » Wed Nov 03, 2010 10:24 pm
The trouble you'll have is finding wheel that wont stick out past the arches.
Re: wheel adapters
Postby johny transit » Thu Nov 04, 2010 12:23 pm
turbotom395 wrote:thanks guys, now what sort of size alloys do you think would look good
Personally, I'd love 16" wheels, just that much bigger than normal but not too silly as there is still a fair bit of tyre. I have been looking into wheels for a while now, considered spacers but adding 20mm before any wheel offset is going to lead to extending the arches surely? I'm wondering about redrilling landy wheels now. Even then I don't think 16" will fit without bigger arches, from what I can find. The easiest solution is 14" slot mag or modulars (if you can find them). But yeh, 16" would look good.
"There's always a way"
johny transit
johny transit
Re: wheel adapters
Postby turbotom395 » Thu Nov 04, 2010 8:59 pm
thanks guys ill get hunting
turbotom395
Re: wheel adapters
Postby tkd 1974 » Fri Nov 05, 2010 9:04 pm
ripbuster wrote:http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260633059054&ssPageName=STRK:MEWAX:IT
DONT USE i bought a set from them then had to get finished of at a local shop
they arent cleaned of they are ruff finished and not de bured ,not even faced of on both sides so dont run true ment to be 20mm thick but 21mm 20.7mm 20.4mm 22mm all over the place
not the only one to say this aswell
tkd 1974
Re: wheel adapters
Postby MrMPuk » Sat Nov 06, 2010 3:30 am
Your's seems to be the only feedback on wheel adaptors and even that's neutral.
Re: wheel adapters
Postby Luke » Sat Nov 06, 2010 9:44 am
they dont look any good to me - dont know exactly what they are made from but tapped holes in ally isnt very good and no centre boss :!:
best off to have them made from steel with studs and a centre boss - ok might cost a bit more but jobs like this should be done right :!:
Re: wheel adapters
Postby tkd 1974 » Sat Nov 06, 2010 7:44 pm
made from billiet alloy
there is a center boss but have to ask for it but not even right size for merc wheels had to get spigot rings
ye tapped holes not good why i got mine re done had studs recest and fitted
ye feed back was b4 i fitted ,,,,, only get so many letters to spell out they are sh*t and at the time was trying to get my cash back
but never got it
tkd 1974
Re: wheel adapters
Postby turbotom395 » Wed Nov 10, 2010 9:31 pm
thanks for the replys lads, im abit confused on what to do now :/
turbotom395
Re: wheel adapters
Postby darkbluevanman » Thu Nov 11, 2010 9:24 pm
tkd 1974 wrote:made from billiet alloy
but never got it
I think Luke meant which material?... most are billet... means it's been machined from a lump of alloy rather than forged in a mould.
darkbluevanman
