waxoil or old oil which?
Postby dcwuk » Wed Aug 09, 2006 7:03 pm
i am thinking of giving the old bus and underneath spray with either waxoil or old oil what do members use?
if you use old oil do you mix it with anything?
regards
'I have opinions of my own -- strong opinions -- but I don't always agree with them.'
-George Bush
dcwuk
Postby gemini » Wed Aug 09, 2006 7:10 pm
oil runs allover use waxoyl
gemini
Postby Luke » Wed Aug 09, 2006 7:31 pm
yeah for what it saves you in the long run invest in some waxoil :D its not that expensive :D
Postby UK_ANDY » Wed Aug 09, 2006 8:48 pm
old oil contains acis of some sort years ago when i worked at an industrial museum we only used white oil or waxol for preservation ,any donated items that came in preserved in old where subjected to a rigorous cleaning program to remove old oil.
old ford's never die they just go faster
Click here to vote for the forum in the Ford top 50 sites!!
UK_ANDY
Postby Guy88 » Wed Aug 09, 2006 8:50 pm
as a temporary measure i use new oil mixed with red diesel to stop the rust. lasts about 9 months befor it needs doing again
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby maxlee » Wed Aug 09, 2006 9:07 pm
i have just finshed painting the chasses of my transit in waxoil underseal. seams pretty good its under seal with waxoil in it 2.5L is £10 from holfords so could get it cheaper from some were eles but 2.5L has dont the chasses on my van still got 1/4 of a tin left and i have blobed it on thick. i would say waxoil as i split some old engine oil in my van and the paint just rubs off the floor leaving the metal bear
maxlee
Postby dcwuk » Wed Aug 09, 2006 11:53 pm
waxoyl it is then thanks for your replies can waxoyl be sprayed on or brushed only?
-George Bush
dcwuk
Postby sc_BK » Wed Aug 09, 2006 11:58 pm
You can brush it on or Waxoyl (Hammerite) make a special sprayer. Guess you could apply it with a std paint gun too?
sc_BK
Postby gemini » Thu Aug 10, 2006 12:19 am
if you have, or can borrow a compressor, get one of these, makes the job easy, waxoyl sprays better when warmed up in a bucket of hot water first
i use one of these empty tins to pour it into,
gemini
Postby Luke » Thu Aug 10, 2006 12:31 pm
i think you can even buy it in those sized cans now :? , the best stuff is called dinitrol same as waxoil but performs better in the long run :D
but its certanly better off on the compresser - gets it right down the insides of the chassis rails 8)
Return to Transit Talk
