My latest project mk2 CI Travelhome LWB
Re: My latest project mk2 CI Travelhome LWB
Postby davev6newman » Sun Nov 21, 2010 8:31 pm
Weather not too bad this weekend, but misty and cold. Still.... some progress has been made and starting to take shape.
Got a bit more flooring down now
And panelled the wall up to the Luton and fitted cupboard carcass that i shortened and stuck extra bit on to follow roof profile.
I could now fit the seat box back in and trial fit the cushions and arm rests, looks excellent!!
Ive just made a start on fitting some gas pipes for the fridge and burners and shall be reporting on that next week hopefully as well as fitting the fuse box, charger and RCD..Not good when your colour blind!! :lol:
davev6newman
Postby paulboyce » Tue Nov 23, 2010 6:37 pm
Having just read through your adventures renovating the camper, it makes my roadranger nearly look straight forward, famous last words. Nearly got the heads off, so far so good, (a head gasket went less than a mile from home after a week of driving around the New Forest), mine seems to be more engine and welding problems.
Good luck
Paul
paulboyce
Postby davev6newman » Tue Nov 23, 2010 8:44 pm
Mine may be the same once ive finished the interior, but i dont want to look that far forward. Hopefully the weather will be with me when the time comes.
davev6newman
Postby madmark » Wed Nov 24, 2010 2:40 pm
that is comeing on so well dave keep it up mate! :wink:
Postby davev6newman » Wed Nov 24, 2010 8:27 pm
Cheers mate :)
davev6newman
Postby jerry2 » Mon Nov 29, 2010 9:17 pm
How do you plan on finishing the walls ? Are you painting them?
jerry2
Postby davev6newman » Thu Dec 02, 2010 8:36 pm
No, painting them will show every mark and join. I intend to use a flexible filler on the joints and use a plain (not ribbed) wall carpet on ceiling and walls, different colour for each.
davev6newman
Postby devadave » Thu Dec 02, 2010 9:33 pm
Dave
I have read the whole post and If it was me I would have gave up when you pulled the units out... :oops: :oops:
fair play to you, that is a great job you have done so far, a BIG pat on the back mate. :D :D :D
Good luck with the rest of the weekends and I look forward to the next instalment..
everytime I try to get out and do some work on my campervan the freezin cold convinces me to forget it... I did manage to rewire my zig unit and replace the feeds from the batteries, however I took it to work and worked in the warm warehouse!! :idea:
Great thread and I have picked up some tips on fitting the toilet I have the same type to fit in my van soon.... well actually when the snow stops. :lol:
devadave
Postby davev6newman » Thu Dec 02, 2010 10:05 pm
I just wrap up warm and grit my teeth! Actually its not that bad once youve started, but come to 3pm the cold really starts to bite!
I cant beleave what i have done myself at times, if it wasnt for this thread you forget just how bad it all was.
davev6newman
Postby Luke » Fri Dec 03, 2010 3:00 pm
Luke wrote:weld in a bulkhead and fit a pickup back :idea: :D
ok i take that back :lol: :lol:
ps. i've moved this over to the progress section dave 8)
Postby davev6newman » Fri Dec 03, 2010 8:14 pm
Thanks Luke, id think you should take that back. You cant sleep in a pick up!!! :lol:
davev6newman
Postby jerry2 » Sat Dec 04, 2010 11:17 pm
Sorry for being nosey but do you mean cheap carpet for the walls or a special one.
Need to start thinking waht to do for mine that's all.
Keep up the good work.
jerry2
Postby jerry2 » Sat Dec 04, 2010 11:18 pm
Is it mot'd yet? Or is it ready?
jerry2
Postby davev6newman » Tue Dec 07, 2010 12:03 am
Its special wall lining carpet that doesnt have any backing on it.
http://www.megavanmats.com/apps/webstor ... how/298422
The van had a mot when i bought it, but its run out now. It will be a while until im ready to do that.
davev6newman
Postby brooks4x » Tue Dec 07, 2010 11:56 pm
Hi, im about to start renovation work on the very same Ci travelhome as yourself, do you know were i would get the head cloth for the roof above the bed above the cab, thanks & are you just putting the guts of a caravan in yours ? i was going to get everything rebuilt in mine, anything else you could help me with would be appreciated, like where i would get wall coverings etc, i live in belfast, thanks, Paul,
brooks4x
