Replacement for the Hijet.
Re: Replacement for the Hijet.
Postby kentgpz11 » Mon Jun 07, 2010 9:58 am
Latest bits & pieces.
Rubbed the rusty bits down with wire wheel on angle grinder.
[url]Image[/url]
Then 2 generous coats of Germolene (No1 rust beater).
[urlImage][/url]
Then 1 coat of Smoothrite.
[url]Image[/url]
That should hopefully keep the tin worm at bay for a while... :?
I didn't bother doing the steps, as they need more than a coat of paint. :roll:
I noticed a bit of water got in to the passenger side footwell during Saturday nights thunder storm. So I'll take off the scuttle panel to see if I can find where it's getting in.
Replaced the steering column with a perfect scrapyard one.
I didn't realise that I needed the key to remove the old ignition barrel, :oops: so I improvised with a hacksaw & drill. :lol:
Replaced throttle cable as it was frayed inside & sticking.
Hopefully, I can start to clean & reassemble the cab now.
Image The 2 tone money pit.
kentgpz11
Finally on the road.
Postby kentgpz11 » Tue Aug 03, 2010 10:42 am
Well it's finally taxed, insured & more importantly roadworthy. :)
The cab was thoroughly cleaned & everything put back in.
We ended up replacing the indicator stalk with a new one, as it was temperamental.
This was the state of the fan belt on our van. :shock:
[url]Image[/url]
So a new set of belts was required. :roll:
We replaced cam belt & tensioner, water pump, power steering belt & fan belt.
Hardest part was removing cam belt cover (sh**ty torx bolts rounding off.)
Also flushed 10 years worth of crap from the radiator.
When we got the van there was a spare clutch cable in the back & the clutch felt quite stiff, so we swapped the cables.
Then the release lever & bearing parted company, lots of fun to get back together. :evil:
Next on the list were the prop shaft centre bearings, as they were a bit sh**ged.
[url]Image[/url]
These were surprisingly easy to change. :shock:
We then checked the brakes & adjusted the handbrake cable up.
The only thing still not working is the speedo. But I will sort this. :roll:
It drives a lot better than when we bought it, everything feels tighter & works properly (except the speedo :oops: .)
It doesn't smell like an arse anymore, thanks to my wife scrubbing the seats & cleaning the headlining.
So you don't feel unclean when you've been in the cab now, which is definitely a bonus. :D
It's great to finally use the van, now we need to re-fit ply lining to the back.
Then we can start on the bodywork!!! :lol: :lol: :lol:
kentgpz11
Re: Update.
Postby kentgpz11 » Sun Nov 21, 2010 7:10 pm
The exhaust on our van has been blowing for a while, thanks to rust and a well dodgy repair.
I bought this complete system for a lwb turbo very cheaply from Ebay.
[url]Image[/url]
Once I compared it to the one on our van, I realised it was very different. :oops:
I found an almost new downpipe in the scrapyard for £10. :D
This was fitted, then we modified the centre box to fit.
But this meant the rest of the exhaust was too short & didn't clear the axle. :(
So it was cut into 3, bent it a bit more & welded up, into this. (My first attempt at mig welding.)
[url]Image[/url]
Our van now has a side pipe, in front of the o/s rear wheel. 8)
The floor in the back of the van was ground down & plates welded in parallel to the wheel arches, as the spot welds had started to rust.
This was then painted with Smoothrite blue.
[url]Image[/url]
I bought some 195/14 wheels & tyres from Ebay, as the front tyres on the van were 185's & the rears were 195's. :roll:
These were fitted & it feels a lot less twitchy now. :)
The MOT is due in December, so I took the van to be tested while I had a couple of days off work.
I expected it to fail, so wanted plenty of repair time.
:D :D :D It PASSED :D :D :D
Just 2 advisories, rear brake pipes slightly corroded & speedo not working.
I can get the brake pipes replaced no problem & I will find out why the speedo doesn't work eventually :x
So far I've changed the sensor twice & checked all the wiring. Next I will try a different speedo.
kentgpz11
Re: Update.
Postby kentgpz11 » Thu Dec 09, 2010 10:48 am
I decided to give our van a facelift as it pretty much sailed through the MOT.
This was before.
[url]Image[/url]
This is after.
[url]Image[/url]
Much better I think. 8)
Might need a bit of Back To Black on the bumper. :lol:
Cut down & refitted the ply lining.
[url]Image[/url]
Just need to make some new door cards now & paint them to match the rest.
The heater resistor died after only a few months (it was only a cheap Ebay jobbie, not genuine Ford.) :(
Instead of buying another Transit resistor & struggling to fit it under the dash, I did this.
[url]Image[/url]
Genuine Ford Fiesta resistor (been in my garage for years), mounted behind grill next to n/s headlight.
Works a treat & should help to cool it, as they get bloody hot.
kentgpz11
Postby matthew2riches » Thu Dec 09, 2010 10:59 am
Looking good 8)
matthew2riches
