3001 - Customised triple axle mk2!!
Postby madvanman » Fri Aug 04, 2006 8:12 pm
digidash temporarily sitting in place, (well i had to play with something when the gas ran out on my welder last night :lol: )
madvanman
Customised!!
Postby FredTransit » Fri Aug 04, 2006 8:29 pm
Ran out of gas? Not good enough, get the MIG out.
FredTransit
Mk2 Trannyist
Postby MarkM » Fri Aug 04, 2006 8:40 pm
This was the 'el' wire I was talking about before
http://www.maplin.co.uk/Module.aspx?Mod ... ht&doy=4m8
Or real fun stuff..sound activated but the same thing
If you actually go in store (instead of online) they should have pinks and reds maybe green too. I was in there today and saw the kits on the shelf.
MarkM
Postby madvanman » Fri Aug 04, 2006 8:51 pm
FredTransit wrote:Ran out of gas? Not good enough, get the MIG out.
i meant co2 gas on the mig :lol:
madvanman
Customised!!
Postby FredTransit » Fri Aug 04, 2006 9:12 pm
Ah right, thought you meant gas welding.
FredTransit
Mk2 Trannyist
Postby madvanman » Thu Aug 17, 2006 1:52 am
started pulling off the fiberglass parts today, to inspect and repair the metal behind them.
I think the backend might need a few repairs :P
going to have to guess how it should be as there is a lot of metal missing, and make a few changes to prevent the ingress of water that has obviously occured in the past.
madvanman
Customised!!
Postby rover » Thu Aug 17, 2006 8:57 am
Ooerr :shock: Theres not a lot there!
Good luck!
Rover.
rover
Postby FredTransit » Thu Aug 17, 2006 10:53 am
Step forward spare scrapper SWB? Would it help?
FredTransit
Mk2 Trannyist
Postby madvanman » Thu Aug 17, 2006 2:19 pm
FredTransit wrote:Step forward spare scrapper SWB? Would it help?
i'm not sure, it looks like there was no ford metal behind the fiberglass section, it was all fabricated pieces except for the very bottom of the original light apetures, the fiberglass panel was not added to the outside skin of the shell, it WAS the outside skin :shock:
madvanman
Customised!!
Postby transitgeoff » Thu Aug 17, 2006 9:25 pm
so that back panel i have for you is no use then :cry:
transitgeoff
Postby madvanman » Thu Aug 17, 2006 9:42 pm
i still need the back valence, the fiberglass part fits between the valence and the rear door frame
madvanman
Customised!!
Postby madvanman » Wed Sep 13, 2006 6:38 pm
ive decided to not rebuild the windscreen frame and replace it instead,
since my mk2 truck is just sitting and rotting away and has a good screen frame its become a donor.
Image Image
im going to change the dash section as well, as 3001 has a few rust holes in the dash and the truck only has light surface rust.
madvanman
Customised!!
Postby FredTransit » Wed Sep 13, 2006 6:42 pm
..........I would go RHD while you are at it, if I were you! :lol:
FredTransit
Mk2 Trannyist
Postby Steve4x4 » Wed Sep 13, 2006 7:07 pm
Hi there, thats one hell of a project you have taken on. I used to get Street machine magazine and remember seeing pictures of it in there. Am I right in thinking it had Granada lights on the back ? Another transit they featured had the metalwork from a granada welded into the back to take the lights I think.
Steve4x4
Postby madvanman » Wed Sep 13, 2006 7:33 pm
Steve4x4 wrote:Hi there, thats one hell of a project you have taken on. I used to get Street machine magazine and remember seeing pictures of it in there. Am I right in thinking it had Granada lights on the back ? Another transit they featured had the metalwork from a granada welded into the back to take the lights I think.
yes it was built using pre-facelift mk2 granada rear lights.
i dont suppose you can remember which issue or year it was in street machine as im still looking for decent images of it so i can get the outside looking original
madvanman
Customised!!
cron
