From Firevan to Servicevan...
Postby Escortcarrier » Sat Dec 18, 2010 11:58 am
Hi all,
Last month I have introduced myself on the newbies topic. I have purchased a '66 firevan which is ready for it's 4th life (from firevan to camper to bandvan to servicevan).
Since then I have been considering which engine to take to change the firevan into a good rally service van. It must be able to pull a trailer (with an old Ford on it of course..) so some hoursepower is required.
The V4 has died, so no problems with taking that out.
First I thought about a Zetec engine, but I wasn't sure about that. A Pinto was an option too, but a bit expensive. Then I found a V6 from a Ford Granada. It was running and still in the car. Nice oldskool engine on a carburator.
So, decision has been made: it will be a V6. I want to keep the flatnose, so that will make the job a bit more difficult.
Pickup of the MK1 (please note, the Shogun has been sold, next time the Transit will be pulling the trailer...)
Removed the V4:
The V6:
Next update will be the fitting of the V6 in the engine bay.
Check out my other Fords on www.autosport-twente.nl
Escortcarrier
Re: From Firevan to Servicevan...
Postby transitandy » Sat Dec 18, 2010 12:56 pm
very nice 8) looking forward to reading this one m8y :D 8)
Postby madmark » Sat Dec 18, 2010 2:32 pm
keep it comeing :wink:
Postby AlanN » Sat Dec 18, 2010 3:48 pm
Nice, look forward to your progress reports 8)
Postby Escortcarrier » Sat Dec 18, 2010 7:18 pm
Update after a day of hard work 8)
Engine mounts have been designed:
The supports for the gearbox:
And a little gap to make room for two extra cilinders. I love my plasma cutter....
Made a start already to close the gap. it's a tight fit with the accelerator:
Escortcarrier
Postby noah » Sat Dec 18, 2010 7:30 pm
good work....
noah
Postby madmark » Sat Dec 18, 2010 7:36 pm
are you still fitting a heater????? :wink:
Re: From Firevan to Servicevan (MK1 V6 conversion)
Postby Escortcarrier » Mon Dec 20, 2010 12:36 pm
madmark wrote:are you still fitting a heater????? :wink:
Yep, we will squeeze that in somewhere :?
Escortcarrier
Postby Escortcarrier » Tue Dec 21, 2010 10:18 pm
Emmm... we thought that we could squeze the heater in, but in practice it didn't :oops:
We are thinking about placing it further to the right or placing a heater from a Mini.
Any other suggestions are welcome. Maybe from madmark?
Escortcarrier
Postby Luke » Tue Dec 21, 2010 10:54 pm
:lol: i'm sure sourcing another heater wont be a problem :idea:
i wouldnt bother with a mini one they have a valve on the inlet to cool it down - bit of a poor design :? i can't think of a suitable one off hand tho :)
anyway look forward to reading about the progress 8)
Postby MinorMatt » Tue Dec 21, 2010 11:00 pm
What are you on about Luke? They don't there is the valve on the cylinder head to control the temp, its nothing to do with the heater itself!
Postby Luke » Tue Dec 21, 2010 11:03 pm
yeah thats it :) its for the heater when you shut it off the heater stays warm untill all the heats gone :D what i mean is without that valve you wouldnt be able to cool it down :? would you :?
Postby MinorMatt » Tue Dec 21, 2010 11:07 pm
yeah but its not part of the heater ;)
Postby Luke » Tue Dec 21, 2010 11:08 pm
i'd just edit my other post :)
what i mean is without that valve you wouldnt be able to cool it down would you :?: there wouldnt be a heat flap on the heater as it relies on the valve :D
Postby MinorMatt » Tue Dec 21, 2010 11:11 pm
it does... but inline valves are easy to get hold of (they are even on the later spi/mpi minis)
