Mk1 and 2 independant front suspension conversion!
Re: Mk1 and 2 independant front suspension conversion!
Postby ginsambo » Tue Dec 28, 2010 10:11 pm
http://www.t1000.co.uk/technical_author ... ng1p_e.pdf
Can someone have a read of this and then tell me if they think the steering geometry of a MK5 is wrong to begin with?
Just went out and had a look and I reckon reading that its slightly positive offset, which is bad, due to the lateral space restriction of the top shock mount and tall wheels/shocks. No wonder power steering is so bad powersliding and cross country on the bumps, its supposed to be slightly negetive.
What did you do when you set up the IFS Luke, or does it work out same as MK5?
My Mk5 was biodegradable and disintegrated with time.
Ford. Committed to the Environment
Finally entered the 21st Century and bought a MK7. Oh Dear.
ginsambo
Postby 24v » Tue Dec 28, 2010 10:32 pm
Thats a great article thanks for that :D
Cosworth mk2 crew cab with IFS
24v
Cosworth Powered
Cosworth Powered
Postby Luke » Tue Dec 28, 2010 10:36 pm
ginsambo wrote:What did you do when you set up the IFS Luke, or does it work out same as MK5?
works out same as a mk5 - the only thing i did was rasie the top mounts to account for the van being lowered :D
Postby ginsambo » Tue Dec 28, 2010 10:42 pm
Oh....so its just as sh*t then.... :oops: :lol: Kidding. I'm getting a laser line on the mk5 wheel tommorrow, chances are its probably spot on and I'm imagining it as usual.
ginsambo
Postby BROWNYS V6 » Wed Dec 29, 2010 12:29 am
Luke wrote:works out same as a mk5 - the only thing i did was rasie the top mounts to account for the van being lowered :D
how much did you raise them up by luke :?:
ginsambo, ive got some negative on my mk3 as i keep scrubbing the insides of the tyres out and ive done the tracking and its spot on :lol: but i did lower it a bit :wink:
BROWNYS V6
Postby Luke » Wed Dec 29, 2010 12:32 am
BROWNYS V6 wrote:how much did you raise them up by luke :?:
i think it was 40mm :? it wasnt the exact amount i was lowering it by i think i just had the chance to raise it by that much if you know what i mean :D to give me more suspention travel :?
Postby BROWNYS V6 » Wed Dec 29, 2010 12:44 am
hmm had thought about doing the same to stop shocks bottomin out,was also toyin wiv the idea of adjustable top mounts like mk2 escort :?
BROWNYS V6
Postby 24v » Wed Dec 29, 2010 11:03 am
Does the conversion raise the ride height over the old suspension height or did you want to lower it anyway?
24v
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Dec 29, 2010 4:43 pm
24v wrote:Does the conversion raise the ride height over the old suspension height or did you want to lower it anyway?
i think the ride height would end up the same but i wanted to lower it anyway - ive just cut down my front springs :D
Postby Luke » Wed Dec 29, 2010 4:44 pm
BROWNYS V6 wrote:,was also toyin wiv the idea of adjustable top mounts like mk2 escort :?
would you have them without rubber bushes in :?:
Postby 24v » Wed Dec 29, 2010 9:24 pm
I would keep rubber bushings to keep down wear but it might flex to much.Hard to know which to go with.
24v
Cosworth Powered
Cosworth Powered
Postby BROWNYS V6 » Wed Dec 29, 2010 9:25 pm
no rubber shite,somfin like this :) cant find escort ones :wink:
http://cgi.ebay.co.uk/Peugeot-205-Adjus ... 2ea7da6df4
BROWNYS V6
Postby 24v » Wed Dec 29, 2010 9:36 pm
They are the ones I was also thinking of as you can get alot of adjustment with them.
24v
Cosworth Powered
Cosworth Powered
Postby BROWNYS V6 » Wed Dec 29, 2010 9:46 pm
jus found these :mrgreen:
http://cgi.ebay.co.uk/Alloy-Adjustable- ... 5ad606f7e5
or am i gettin to technical now :lol: more work :roll:
BROWNYS V6
Postby 24v » Wed Dec 29, 2010 9:53 pm
They are better again caster and camber adjustment.I saw something like that fitted to some track subarus but not with as adustable as that.As you say some thing to think seriously about.
24v
Cosworth Powered
Cosworth Powered
