when i was into them i used the later block called the stiff block this was the type that was fitted to johno,s van!
great engine i use to get 24mpg out of mine
BROWNYS V6 wrote:whats the gearbox bw 35 or 65
Luke wrote:BROWNYS V6 wrote:whats the gearbox bw 35 or 65
no idea! anyone know from the picor how do i tell
madmark wrote:if i remeber the compreshion ratio with be down were the dipstic tube is as paul saysif its erly p5/6 it will have rope seals
great engine i use to get 24mpg out of mine![]()
and it sounded awsome!
yep - it's a BW45BROWNYS V6 wrote:Luke wrote:BROWNYS V6 wrote:whats the gearbox bw 35 or 65
should be a small alloy plate on the side
missed this post - i'll have a lookmadmark wrote:if i remeber the compreshion ratio with be down were the dipstic tube is as paul says![]()
madmark wrote:if its erly p5/6 it will have rope seals![]()
Luke wrote: it's a BW45
