looneyfitter wrote:Hey all i thought id start a new thread as will make it easier if other people have similar probs. Right I have a 85ps transit and the cam carrier snapped. I managed to get hold of a a 52 plate mondeo 115ps all with the same type of turbo as mine etc (not variable vain) I have swapped over
Pump, injectors, turbo, alternator, PCM (ecu), and transponder. The van starts 1st time no probs at all but only runs for about 10secs? She revs up etc then cuts out.
What i have noticed is that some of the lights on the cluster are acting funny ie, the service light stays on, the battery light is off when not started and on when is started, Also the digital display has four dashes.
Any ideas? Really need my van for work now as im back in on Thursaday.
Cheers People.
Gareth
Yeah mate but they were different....winterheating wrote:did the 2 connections not fully remove from the fuel pump so you could connect the transit pump ones
