ESP light
ESP light
Postby mrspodrod » Sun Jan 02, 2011 8:05 pm
Hi there I recently bought an 07 jumbo 115/350 happy out with it nice van. My problem is I drive about 8miles from cold and the ESP light comes on. When I stop and restart it goes off again drive 7/8 ish miles it comes on again. The ESP worked very well in the recent snow coming on when wheels were spinning wouldnt let you over rev, but the roads are back to normal now but full of pot holes anyone any ideas?? :? :? :?
mrspodrod
Re: ESP light
Postby robbie.cee » Sun Jan 02, 2011 9:30 pm
is the switch lit up saying off?
Had
X-Reg Mk5 150ps 3.0 ESSEX V6
MAKE IT FIT
robbie.cee
Re: ESP light
Postby mrspodrod » Sun Jan 02, 2011 10:01 pm
robbie.cee wrote:is the switch lit up saying off?
Hi Robbie No the off light on switch is staying off its the two squiggles(ESP light) on rev clock coming on and staying on
Any ideas?
cheers Mick
mrspodrod
Re: ESP light
Postby robbie.cee » Mon Jan 03, 2011 12:14 am
not an abs flt is it? i turned esp off in snow to rag nuts off van when stuck, but comes bk on after you go over 60.if your light is staying on i reckon you need code reader to check em. argos sell em now for 120 quid!!!!!!!! if not ford charge 80 quid just to put in grg...then code reading ll cost more...
Had
MAKE IT FIT
robbie.cee
Re: ESP light
Postby furnitureman » Mon Jan 03, 2011 5:20 pm
Hi this happens to me now and again its probably one of the sensors on the wheels have a look and clean the area if its like mine it only happens every now and then and wont throw up any codes, as for code readers there are a few f super readers on the bay for around £30 - £50 these are the ones to get.
MK7 2006, 2.4 tdci, 140ps + TUNIT box = 165ps jumbo rwd known as "Big Blue" to the kids.
furnitureman
Re: ESP light
Postby robbie.cee » Mon Jan 03, 2011 7:15 pm
furnitureman wrote:Hi this happens to me now and again its probably one of the sensors on the wheels have a look and clean the area if its like mine it only happens every now and then and wont throw up any codes, as for code readers there are a few f super readers on the bay for around £30 - £50 these are the ones to get.
f super reader- can you expand on that- model etc
many thanks (from me and every one else no doubt!)
rob :D
Had
MAKE IT FIT
robbie.cee
Re: ESP light
Postby furnitureman » Mon Jan 03, 2011 8:22 pm
This is one on the bay i got mine cheaper but no customer servicehttp://cgi.ebay.co.uk/Ford-Super-F-Scan ... 3363ce8bd2
they can be a pain to get working via your laptop if you dont have a laptop tryhttp://cgi.ebay.co.uk/U480-CAN-BUS-OBDI ... 4155a9db2f
I had this before i got my transit it works on most cars and will give you the codes and let you re set the codes, works well on the transit just not as indepth or usefull as the f super it all depends on how good with working on cars / vans you are as to how much info you will need.
i am keeping both as i leave the small one in the van and will use the f super when i need more info.
Hope this all helps.
furnitureman
Re: ESP light
Postby robbie.cee » Mon Jan 03, 2011 8:30 pm
christ the second one is 80 quid in argos!!!!!!
cheers for links m8,
can you play with limiter on it do you know or is that for the pros??? :)
Had
MAKE IT FIT
robbie.cee
Re: ESP light
Postby furnitureman » Mon Jan 03, 2011 8:33 pm
Vantuner is the man for altering the limiter give him a pm.
furnitureman
Re: ESP light
Postby DEAN MACHINE » Mon Jan 03, 2011 9:11 pm
the esp light on my jumbo on the dash is also the management light, fault code? :idea:
DEAN MACHINE
Re: ESP light
Postby ake » Tue Jan 04, 2011 9:14 pm
DEAN MACHINE wrote:the esp light on my jumbo on the dash is also the management light, fault code? :idea:
Only for the esp tho :?
Re: ESP light
Postby DEAN MACHINE » Tue Jan 04, 2011 9:37 pm
no its for all i think ,if you disconect the map or maf senser it puts on the esp light and van goes into limp mode
DEAN MACHINE
