engine starts then dies
Postby eddie t.n.t » Thu Aug 24, 2006 7:46 pm
hi everyone had this problem for awhile now,i do a lot of stop start work during the day,about 30-40 times on off with the engine.a lot of the time the engine will start and then die straight away try again and its fine.had this niggling problem before and after a fuel filter change so don't believe its that.any ideas? forgot to say it's a 90ps 2.4 diesel 53 plate.
eddie t.n.t
eddie t.n.t
Postby MrMPuk » Thu Aug 24, 2006 7:58 pm
Does the Glow plug light come on?
Postby eddie t.n.t » Thu Aug 24, 2006 8:08 pm
it has come on before and caused the engine to revert to idle but that was a problem with the accelerator pedal.in a word no.
eddie t.n.t
eddie t.n.t
Postby MrMPuk » Thu Aug 24, 2006 8:11 pm
Take a look at this post it might be of help.
http://fordtransit.org/forum/viewtopic. ... =nighthawk
Postby eddie t.n.t » Thu Aug 24, 2006 8:26 pm
had a look at that post.my van isn't quite the same as it doesn't struggle to start after cutting out,starts straight away.its something i can live with just worried it's going to hurt in the pocket in the long run (fuel pump?).
eddie t.n.t
eddie t.n.t
Postby MrMPuk » Thu Aug 24, 2006 8:29 pm
I think it's the same as that post as your van sounds like the same fault as my mates which is what me and Nighthawk were talking about when he gave me the info.
Postby eddie t.n.t » Thu Aug 24, 2006 8:42 pm
nighthawk knows his stuff , i will run it pass a diesel fitter i know thanks for the help
eddie t.n.t
eddie t.n.t
