shortie2 wrote:Van was running fine ,stopped to nip into workshop ,went back out and the van wont start, tried locking /iunlocking using the fob but as soon as you put key in the ignition position the red led goes from solid then flashes very fast ,all the ign lights etc come on but the starter wont engage, if you then turn off and back on quickly the engine will turn say 3 turns then starter relay clicks off.
The battery seems normal and fully charged
Has the key fob lost its code?
its a 350 lwb 140ps 07 plate btw
shortie2 wrote:in the key fob? its still working all the central locking etc
Timbo wrote:Have you been using the fob a lot without putting the key in the ignition ?If you have it may just be the "battery" in the fob has run out. It gets charged up from the van when the key is in and the ignition is on.
