Symptoms were - at 70mph ish the oil light came on, sudden loss of power - the clutch went straight in and we pulled the van over, engine still running. Turned off.
Oil/water level was fine, nothing suspicious to be seen.
Started up after a few minutes cooling down but the pull was lacking.
Stopped again, got passengers out to lighten the load and got a bit further before it cut out completely.
Turned over but cut out, then wouldn't turn over (just the 'click').
Anyone recognise this? Is it terminal...?
New engine? If so - any idea of prices????
Its a 2.5 Di done around 140k, well serviced and maintained.
...off for a bloody good cry.
