Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Re: Luke's Minibus 1st V6 24v cosworth now fitting a 2JZGTE
Postby BROWNYS V6 » Fri Mar 11, 2011 11:26 pm
jus been watchin a vid on u tube,2jzgte powered 3 door sierra :shock: sounded good :wink: are you gonna run yours thru the sidepipes or u doin summat else :?:
BROWNYS V6
Postby Luke » Fri Mar 11, 2011 11:39 pm
summat else :lol:
post us the link i havent seen that :mrgreen:
Postby BROWNYS V6 » Fri Mar 11, 2011 11:47 pm
http://www.youtube.com/watch?v=R93I75_a ... re=related
wheels look fookin awful, but sounds the dogs nob :lol: goes like fook too :wink:
BROWNYS V6
Postby Luke » Fri Mar 11, 2011 11:50 pm
nice 8) 8) doesnt seem to like going in a strait line tho :lol: :lol:
Postby BROWNYS V6 » Fri Mar 11, 2011 11:52 pm
yea hope you got plenty of steering lock in ur van :twisted: :lol:
BROWNYS V6
Postby Luke » Mon Mar 14, 2011 1:11 pm
BROWNYS V6 wrote:yea hope you got plenty of steering lock in ur van :twisted: :lol:
that might be a project for the future :idea: transit quickrack :D
but ...............my wheels have arrived this morning 8) 8) 8) 8) 8) 8)
unfortunatly can't try them on as ive got to go to work :( :lol:
Postby BROWNYS V6 » Mon Mar 14, 2011 11:37 pm
Luke wrote:that might be a project for the future :idea: transit quickrack :D
quick rack in a transit, hhmmm :lol:
come on show us ya wheels :D that last pic was pants :lol:
BROWNYS V6
Postby G40GES » Mon Mar 14, 2011 11:44 pm
Luke wrote:just google them and there is a chargecooler vs intercooler 'discussion' on just about every forum :lol: looking at it this way i want
still got prop to sort but wiring loom is getting closer :| :lol:
p.s. gadge ive put your other post in the north weald thread :D
er HELL YEA good job someones keeping tabs :wink: :lol:
Gadge in the shed... STILLfreezing me bits off...
G40GES
Postby G40GES » Mon Mar 14, 2011 11:49 pm
CHARGE COOLER :!: :!: :!:
and the hoops are TIDY :!: :mrgreen: :mrgreen: :mrgreen:
G40GES
Postby Luke » Wed Mar 16, 2011 1:40 pm
more wheel pics then :lol:
for comparison ........... OLD
NEW
hmmmm might be a problem here :lol:
but worth it 8) 8)
just look at the extra dish 8) 8)
trying to work out what tyres i need gonna be 245's but either 50 profile or 55 :) 50 should give me the same rolling radious as the old ones but i always planned on swapping them for a larger profile for cosmetic reasons - but i dont know if i'll have arch clearance problems with 55's although the weight is on the axle in the pic - but long term i plan on lowering it a bit :D
either way i dont suppose it matters much as i cant see the tyres lasting long :| might see what it's like on the 50's 1st :D
Postby Luke » Sun Apr 17, 2011 10:23 pm
seeing as i've not updated this for so long it's fell off the 1st page i thought i'd better update :lol:
not really done a great deal as ive been busy with other stuff but i've had an adapter plate made for the prop - pics to follow when i collect it :D
made this for the gearbox - it picks up of the now redundant rear leaf spring mounts and uses the toyota standard rubber block :D
other stuff ive done is lay the wiring loom in place and make sure it all reaches, the ecu will be inside the cab on this one :D this is what it looks like :D
Postby BROWNYS V6 » Sun Apr 17, 2011 10:29 pm
hmm nice wheels 8) cant u stretch some skinny tyres on there to keep um under the arch :)
BROWNYS V6
Postby Luke » Sun Apr 17, 2011 10:30 pm
BROWNYS V6 wrote:hmm nice wheels 8) cant u stretch some skinny tyres on there to keep um under the arch :)
i'm hoping the 245's will be just under the arch :| :lol:
Postby AlanN » Sun Apr 17, 2011 10:43 pm
:lol: rubber arches dude :lol:
Postby Luke » Sun May 01, 2011 5:36 pm
Bit more done today :D
got this oil cooler for the autobox - it's quite big but it's gonna be fitted under the van so might not get the airflow it would on the front so i thought go larger - ive also got a square one so i can fit a fan if i need :idea: just need to make up a mounting bracket and weld on some smaller fittings to it :D
After reading AlanN's thread i thought if thats the standard of todays modded transit then i'd better paint my gearbox crossmember :lol: it's now fitted and the engine box is in it's final position :D
I'm getting to that stage where one job needs another done 1st before i can continue, like i need the radidator but i cant get that made untill i've got the fans as the space is so tight i need to trial fit them to the mock radiator then get the dimentions spot on, so thats next job - along side that is the wiring i need to find the pinouts for these connectors :|
it's looking close to get it done for north weald :| i'm also starting a new job so i'll get a bit less time on it, but i'll try my best :mrgreen: and wether i'm racing or not i'll be at weald 8)
