Tran59 wrote:Fantastic work and thanks for sharing. The only thing I'd be worried about is not getting back the hours you have spent on the immaculate interior before the rest of the van packs up. Pity it's not a 1- or 2-year-old Mk7...
Nadjenka wrote: Undestroyable (almost) if you don't let me drive it...![]()
dachre wrote:Made the Fiamma porta loo box.... or the crap box as I like to call it....
Simple stainless frame with some ply stuck on it.
Then stuck some wall carpet on it so it matches the rest of the box seats.
The top section is hinged but it's also attached to the front section. So when the top is lifted the front lifts also. This is to gain access to the control parts of the loo which are also at the front.
If I do take the crap box with the camper it can be situated right at the back.
Or behind the drivers or passengers seats.
But I have been waiting for the Foam seats from The Foam Shop to be made. In the entire campervan project these are the only items that had to be made that I haven't fabricated for the camper myself. So I was glad when I got the call to come down to Taunton and pick them up and see what they looked like....
I was hoping that they'd look like my initial drawings and I think they've done a fab job of that.
Its a modular system so all the cushions, arm rests and other bits and bobs can move around.
The arm rests can also go at the back door for a back support, ect.
The small foam square section fits on the little box I just made to create an 'L' shape sitting arrangement.
And if you take the little box out from the back of the van, a walkway right from the back doors to the front of the van is created. This walk-through idea is something that I've always wanted but its taking a lot of work to produce........ I've had to level the floors up, move the handbrake, ect..... But it works great and when the front seats are turned around it makes a nice uncomplicated living area.
The other idea I wanted to create is the largest fold out seat-bed I could. So I've utilised every square inch and kept all the sides of the van as flat and unobtrusive as possible when designing and building it.
From the side of the van to the kitchen unit and from the back of the van to half way up the length of the side door. This gave a size of 4'2" x 6'4" or 1260mm x 1920mm approx.
And the good thing about the modular seating system is that you can do different things with it.
In this example I've left the back seat-bed out and made a large 'L' shape sitting area at the back of the van.![]()
And I think we really are coming to the very end of the campervan build...Its just curtains and a few other bits and bobs left to do........
I've just parked the van up for the worst of the winter so I'll be in no rush to finish.... but then I don't think I ever have been..........
Cheers guys.....
