Cosworth bits
Cosworth bits
Postby Guy88 » Mon Sep 11, 2006 9:02 pm
Right i have just bought a Granny v6 24v.
Simple question. what bits do i need to rob from it to fit it to a MK3 and do it manual. i will only be able to have the car here for 2 days as i have no space. 1 day i hav set aside to get the loom out.
A list of bits would be useful :wink:
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby bj928 » Mon Sep 11, 2006 9:33 pm
first off what year reg is the car, or easier still what colour are the front indicator lamps, clear plastic or amber plastic, hope they're amber cos it'll be a lot easier
bj928
Postby Guy88 » Mon Sep 11, 2006 9:44 pm
Afraid to say there clear :(
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Sep 11, 2006 9:53 pm
well ........................ you will need to save the engine :wink:
Postby Guy88 » Mon Sep 11, 2006 9:55 pm
Thats where i go wrong :lol: :lol: :lol:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby bj928 » Mon Sep 11, 2006 9:57 pm
oh well, its not an easy car to take apart but if you take your time you'll get there in the end, as your scraping the car afterwards the easiest thing to do is cut the slam panel out between the lights, and take the rads out,
have you taken an engine out of a car before.
easier to take engine and box together
you have to take the oil remote off or the engine won't come past the steering very easy.
bj928
Postby Guy88 » Mon Sep 11, 2006 10:00 pm
getting bits out i can do. its knowing what to take out :wink:
What flywheel do i need to get or will the pinto one do :?:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Sep 11, 2006 10:04 pm
have you got the adapterplate :?:
Postby Guy88 » Mon Sep 11, 2006 10:05 pm
Going to get the pinto one drilled
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby MrMPuk » Mon Sep 11, 2006 10:06 pm
You have to ad a bit to the pinto plate first.
Postby Guy88 » Mon Sep 11, 2006 10:08 pm
Thats ok. im going to takr it to college and borrow a welder :roll:
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Mon Sep 11, 2006 10:08 pm
well i'd save the auto box too then just incase you cant find a flywheel - wouldnt be too much to hassle to fit the auto then convert to manual later :? :idea:
Postby bj928 » Mon Sep 11, 2006 10:10 pm
once the engine is out you will need the loom, this is the hard bit as you have the later car with a second big fuse box next to the battery, basicly the engine loom starts round by the abs and goes round the front of the engine bay and into the car behind the abs pump on the passenger side.
inner wing on the driver side is the EDIS 6, don't forget it, its easy to forget i know, i've forgoten it myself before, its best to unbolt the abs pump so the wiring feeds through a lot easier, this is done with i think 3 bolts got at from the wheel arch.
as for the wiring from inside the car, its just a case of getting it out the best way you can, i'll have a word with my mate in the morning as to what you need from inside and from the big fuse box as i leave the wiring to him, so he know what to grab out.
bj928
Postby Guy88 » Mon Sep 11, 2006 10:14 pm
cheers mate. was thinking of going auto but il see what happens.
One other things what do i need to connect the wires to in the van. where is the plug where the engine loom joins.
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby bj928 » Mon Sep 11, 2006 10:17 pm
its not as simple as that, my mate charges £150 a time to wire them up but thats only cos most people cant be bothered to work it out, and yours is the more difficult one to wire up,
when are you planning on takeing the engine and loom out of the granada
bj928
Return to Transit Talk
cron
