Started On Miss Piggy
Re: Started On Miss Piggy
Postby greek » Fri Oct 29, 2010 2:49 pm
Thanks all glad you like it, I like it but not as much as the one that got burnt that had a bit sentimental value plus it was original , I also don`t like the windows the old ones were ali framed & looked a lot better but hey ho it will do, don`t think there will be that many about with the Cotswold coachbiult body on it although I have seen a commer & old Bmc with a cotswold body on it. Some of you might not have seen my 1st one
I`m to old to lie under Transits
greek
Postby gfdiamond » Sun Oct 31, 2010 12:40 pm
hi greek,
its looking great mate......thanks i got to see the photos...!!
wouldnt mind seeing some interior ones as well.
regards,
geoff.
GFDIAMOND
gfdiamond
Postby greek » Sun Mar 27, 2011 8:45 pm
Done my passenger seat this week & as one or two of you took an interest in the last seat i did thought I`d post it bit by bit, but remember I`m just a lorry driver not an upholsterer so if anyone follows my methods I will not be held legaly responsible for any cock ups :lol: :lol: :lol:
Damaged seat
Cover is fastened underneath with metal clips undo with long nose pliers
Take damaged panel out by undoing stitching cut your panel out correct size leatherette bought from most fabric shops half a metre is the least you can buy cost £4, pin in place
Get the missus to sew new panel in it helps if you use needles that are for leather as the piping you sew the panel to is quite thick
Put cover back on seat pull the corners in first then fasten the rest making sure you have the cover on straight I used good old cable ties instead of reusing the metal clips worked on the first seat so should be ok
Finished job looks passable quite a bit cheaper than an upholsterer
Hope this might encourage one or two of you to do it yourself
Did a bit more to piggy today took front springs off got an advisary last MOT bushes Knacked so will see if I can get meself some somewhere
greek
Postby Altransit » Mon Mar 28, 2011 9:58 pm
Looks spot on to me 8)
Postby roelsmits » Wed Mar 30, 2011 6:18 am
good work :!: :!:
I got mine don for € 500 :?
roelsmits
Postby greek » Mon Apr 11, 2011 9:14 pm
Got an advisory last Mot, front spring bushes so thought I`d get it done before I put it back on the road next month, nearside front brake sticking with it standing so cleaned the wheel cylinders up while I was on . Had to have a look around before i found a place on net down in Somerset prompt service but not cheap :(
greek
Postby madmark » Mon Apr 11, 2011 9:22 pm
:shock: is that a expensive exhaust i see there :lol: :lol:
Postby greek » Mon Apr 11, 2011 10:30 pm
On when I got it Mark front pipes look rusty but back end stainless, looks like made to measure :D
Was going to paint springs back plates etc but you know i`m not into custom :lol: :lol:
greek
Postby greek » Mon May 02, 2011 5:08 pm
Think I`m done now :roll: :roll: :wink: finished except for carpet in the back here`s me final pics custom badges back on seats in, couple of fog lights
greek
Postby madmark » Mon May 02, 2011 6:02 pm
8) looking great mate top work :wink: :wink:
Postby noah » Sun May 08, 2011 1:08 am
good work
noah
Postby GPM01 » Sun May 08, 2011 1:39 am
Me likey 8)
If you want a real van.......You gotta get a Transit!!!!
GPM01
Postby screechowl » Sun May 08, 2011 9:45 am
roelsmits wrote:good work :!: :!:
What did you get for that mate? I'll need complete re-build of my camper if I keep. Just having MOT & bottom done at present.
screechowl
Postby roelsmits » Thu May 12, 2011 3:55 pm
that was about the seat covers :lol:
I have a company make them :roll:
roelsmits
Postby greek » Sat Jun 04, 2011 4:49 pm
bump, just to help Alfie
greek
