Sport mods
Re: Sport mods
Postby redcube » Sun Apr 17, 2011 9:48 pm
I like the job you have done so far going to watch this one
redcube
Re: Sport mods
Postby alcapone » Sun Apr 17, 2011 10:50 pm
redcube wrote:I like the job you have done so far going to watch this one
Still got lots to do, but can get on now the side windows are in. :)
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby alcapone » Mon Apr 18, 2011 9:47 am
Tape off, windows still in, job done! (though I will be much happier once I've driven it) :)
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby AndyJ2506 » Mon Apr 18, 2011 11:03 am
your brave :shock: thats a brand new sport van your cutting up :? :lol: Looks good tho mate and a good how to guide 8) :mrgreen:
Call 07739463511
AndyJ2506
Re: Sport mods
Postby alcapone » Mon Apr 18, 2011 11:24 am
AndyJ2506 wrote:your brave :shock: thats a brand new sport van your cutting up :? :lol: Looks good tho mate and a good how to guide 8) :mrgreen:
I must admit, it is a bit nerve racking drilling a hole through then scraping a line on the nice shiny paint work. One of the advantages of the bonded windows is they cover more area than just the hole so any small mistake is hidden by it. I'm just hoping they stay in when I drive over the pot holes down the road! :)
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby AndyJ2506 » Mon Apr 18, 2011 11:27 am
They look good mate and if your attention to detail is anything to go by you'll be fine :D
Call 07739463511
AndyJ2506
Re: Sport mods
Postby alcapone » Mon Apr 18, 2011 12:17 pm
I'll do the back door windows some time, but they will be easy. I need to concentrate on the inside a bit more first. I'm hoping to get the roof lined this week and get my 8ft LED strip light in :)
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby g-man » Mon Apr 18, 2011 2:09 pm
top job 8)
g-man
Re: Sport mods
Postby alcapone » Mon Apr 18, 2011 2:55 pm
g-man wrote:top job 8)
Thanks :) The windows and sticking carpet to the window moulding was a first, but it seems to have worked out quite well :)
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby alcapone » Mon Apr 18, 2011 8:20 pm
Finished work and was straight onto the van. More carpet was stretched around the odd shapes and the first two roof panels were put up.
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby belly » Mon Apr 18, 2011 8:58 pm
Nice work 8) You can get a bit of trim from ford that goes in front of the glass between the seam if that makes sense ? Oe Ford double cabs have it :wink:
belly
Kaiser Chief
Re: Sport mods
Postby alcapone » Mon Apr 18, 2011 11:54 pm
belly wrote:Nice work 8) You can get a bit of trim from ford that goes in front of the glass between the seam if that makes sense ? Oe Ford double cabs have it :wink:
Yeah, I think I know the stuff you mean, like a thin strip of glass to fill the gap? I've seen it on a few vans and may go for it just to tidy things up a bit.
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby belly » Tue Apr 19, 2011 10:47 am
Yeh that's the ones, they just give it that pukka touch ;-)
belly
Kaiser Chief
Re: Sport mods
Postby alcapone » Tue Apr 19, 2011 10:52 am
Yeah, might have to go for a couple of them, I've got loads of the glue left so just need the bits of glass.
alcapone
Sportvan Owner!
Sportvan Owner!
Re: Sport mods
Postby alcapone » Tue Apr 19, 2011 9:00 pm
Not so much done today, the lack of light caught up with me.
I experimented with diodes for the lighting circuit and decided a bridge rectifier was better than two diodes, mainly because it had a hole in the middle which would allow me to screw to something or other. Also need to consider the current. Each of the LED strips is about 0.7A and I have six of them, so about 4.2A. A 6A bridge rectifier was chosen. More on the lighting and a final circuit diagram later.
The LED strip light was finished off with a terminal block in the right place to match the hole in the roof centre panel. The centre panel was cut and covered, but waiting for paint to dry on a bracket I made for the rear end.
Carpet cut and sprayed with glue.
Panel also cut and sprayed with glue. Not two holes - the small one is for the terminal block on the back of the LED strip light and the bigger one is where the original light would be. I've put a hole there in case I need to get to those wires in the future, but will cover it and leave it covered.
Carpet wrapped onto panel and smaller of the holes cleared.
The bracket that will hold the back end up, made from angle ali with the corners sanded down.
alcapone
Sportvan Owner!
Sportvan Owner!
