My Mk1 Transit's Restoration Project
Re: My Mk1 Transit's Restoration Project
Postby roelsmits » Thu Sep 23, 2010 9:00 am
have you figuered out how you are going to do this?
greetings roel
roelsmits
Postby malta transit » Thu Sep 23, 2010 8:47 pm
Yes, thanks to you. But first i have still to do the middle panel. I will ask you if i get stuck if you don't mind. 8)
malta transit
Our man in Malta!
Postby malta transit » Thu Sep 23, 2010 9:19 pm
This week all i have done is , i welded the panel i fabricated to the imitation panel ( i spot welded them together,overlap them )
and gave it a lick of paint from the inner side where i can't reach after welding it in place.
Today i bought a litter of RUST REMOVER and applied it to here, on the edge of this panel,
It works magic,as i applied it by brush, the liquid eliminates all the brown rust and a shinny metal stip appeared. after wiped it with a wet cloth ( as dirrections ) i painted it to protect it.
A new lower panel i could not find here, so a trip to my friend Karmnu found myself a second hand one. It had some rust patches and the very end was very bad, so after i sepperated the lower part from the upper part i cut away the rusty 3inches and welded a new fresh metal.
Then i sanded of the offending rusty parts and cleaned it with rust remover,then i brush painted it temporary.
Next step will be putting the panels together and weld them. Fingers crossed! As i'm very nervois in doing the outer parts :?
malta transit
Our man in Malta!
Postby roelsmits » Fri Sep 24, 2010 9:35 am
malta transit wrote:Yes, thanks to you. But first i have still to do the middle panel. I will ask you if i get stuck if you don't mind. 8)
I don't mind but I think jou'll manage.
I can see you'll doing a great job :D
roelsmits
Postby irishtransit » Fri Sep 24, 2010 10:28 pm
that looks like some tidy work you're doing.keep at it you'll be pleased when it's all finished.
irishtransit
Postby Per Olav » Wed Sep 29, 2010 9:48 pm
Keep up the good work "Malta transit" looks nice. :)
PO
Per Olav
Postby malta transit » Fri Oct 15, 2010 10:42 pm
These two weeks since my last post were a nightmare. As i have never done the outer parts were they are visible. The middle imitation panel was not perfect,the edge were it meets the wheel arch don't match. And the panel is slightly concave. But i have done my best.
First i have spot welded the middle panel at the top edge from the inside,through the holes i had punched with my joddler. I was advised always start from the middle,then outwards so you don't have bump warps.Then i welded the edges of the middle panel with that against of the floor panel.
Then i linished flat the spot welds against the floor only as the ones in the cannal i could not get to them. Then i also painted them not to rust.
When the middle top panel was done and strong, i spot weled the lower edge to the new flat panel i had made.
Then i linished the spot welds with a grinder.
This is how it looked from the outside.
Then i tacked welded through the holes i had made the last lower panel from beneath.
This is how it looks from the outside.
Lastly i linished the welds and painted the welds.
Finished nightmare part 1 :evil: :twisted:
malta transit
Our man in Malta!
Postby rover » Fri Oct 15, 2010 11:45 pm
Nice work :!:
Keep at it mate, you will get there in the end :D
rover
Postby roelsmits » Sat Oct 16, 2010 8:40 am
I thought you did a good job done, I even walked out just to see what it looked like mine.
What I can see the pictures it looks good!
next time I like to see more :D :D
When you're done, he is well again for 40 years
You'll get there :D
roelsmits
Postby malta transit » Thu May 05, 2011 2:25 pm
Its been 8 months since i v done something on my van, but at least i got my muse back.
I started by welding up the small drilled holes on the loading floor which were useless for me.
Then after thinking how am i going to cut the small rusty holes, i decided to cut a big section :shock: so i cut big.
Then i had a bit of work to remove the out rigger to make a good copy for both sides,
As i had the back corner removed , i patched up the bottom part of the rear wheel arch.
From inside :
From beneath :
Then i cut off the rear botom panel and cleaned of the remaing metal;
This is how it looks at the moment,
After i will fill up and smoth the wheel arches with filler ,were i v welded i will cut up these two rectangular molds and weld them on the new metal.
malta transit
Our man in Malta!
Postby madmark » Thu May 05, 2011 5:01 pm
:shock:looking good keep up the good work :wink:
Postby alcapone » Thu May 05, 2011 7:19 pm
There's some good fabrication there, it looks like you're using stainless steel? My MKI Transit left me with about 20% of it repaired with stainless (including the whole of one inner wheel arch done in polished stainless). I knew I'd never have to do the same job twice then :)
Keep up the good work, I'll be following this thread! :)
alcapone
Sportvan Owner!
Sportvan Owner!
Postby malta transit » Fri May 06, 2011 7:37 am
alcapone wrote:There's some good fabrication there, it looks like you're using stainless steel? My MKI Transit left me with about 20% of it repaired with stainless (including the whole of one inner wheel arch done in polished stainless). I knew I'd never have to do the same job twice then :)
No,i'm not useing stainless steel. Just galvanised sheet metal,and brush out were you need to weld, if not the weld would not fuse. 8)
malta transit
Our man in Malta!
Postby alcapone » Fri May 06, 2011 8:46 am
It's a shame they don't galvanise the whole van before painting it :)
alcapone
Sportvan Owner!
Sportvan Owner!
Postby irishtransit » Sat May 07, 2011 12:04 am
good to see you are back at it.looking good as usual.
irishtransit
cron
