fedup2 wrote:The whole intake gets the same way thats EGR's for ya
HA54SYM wrote:OK bit of an update as had some time to do things.
Took the EGR off, all looked fairly normal, although I could not open / move the valve stem at all. so not sure if its working or not?
Decided to also check the map sensor, and as it was so badly covered in crud, I took the whole inle off and cleaned up as much as possible. Could not believe the amount of build up in it!
Not sure if this is normal, or if it is a sign the EGR is not working.
Anyway assembled back together, and still smoking after an afternoons run.
So what next, do I swap the EGR as a matter of course, it rule it out?
Only other thing I did notice was that on one of the injector inlet to heads, it had a lot of what presume is fuel deposit around it. the others looked dry, dirty but dry. Would this be a sign of faulty injector causing over fueling and smoking?
Dave
Users browsing this forum: Google [Bot], Google Adsense [Bot], Majestic-12 [Bot]
