AK's Camper conversion - Ex Network rail
Re: AK's Camper conversion - Ex Network rail
Postby dan_w » Mon Apr 25, 2011 10:20 pm
Ake where did you get your info for the instalatiion of gas bottles and lockers for motorhomes, i think im in the process of cocking up and it would be good to get some clarification before i commit. oo and sorry to go off topic. your van is looking great by the way keep up the good work.
regards Dan
dan_w
Postby MrMPuk » Mon Apr 25, 2011 10:22 pm
dan_w wrote:Ake where did you get your info for the instalatiion of gas bottles and lockers for motorhomes, i think im in the process of cocking up and it would be good to get some clarification before i commit. oo and sorry to go off topic. your van is looking great by the way keep up the good work.
regards Dan
The sticky at the top of this section is a good start.
Postby dan_w » Mon Apr 25, 2011 10:25 pm
what the sticky says and what Ake said were a world apart, going from the sticky id be fine going from what Ake said i wouldnt. thanks though
dan_w
Postby MrMPuk » Mon Apr 25, 2011 10:27 pm
dan_w wrote:what the sticky says and what Ake said were a world apart, going from the sticky id be fine going from what Ake said i wouldnt. thanks though
As I said, a good start.
Postby sinbad » Tue Apr 26, 2011 5:11 am
Hello,
Looks like you are doing a great job! Lots of work. From one of the photos I see a Dometic RM2193 absorption refrigerator. They work great as I have had two of the. Suggest if you use the propane version, which works fine, you provide an air input low and air output high. This will remove heat generated and make refer run better. A small fan is added which I run when it is hot outside, it helps a lot in keeping the temperature low. I added a switch for the fan and LED light (which draws very little) so I know when the fan is on.
Is your Transit a Mark VII, 2006 or newer. I am considering doing a conversion and would love two dimensions: from metal van floor to the bottom of the rear door windows and height of rear van windows. Since I am new to the Forum, I do not know how to add photos - I have a photo of the refer, vents and fan I would like to send you.
Thanks,
Sinbad
sinbad
Postby ake » Tue Apr 26, 2011 6:42 am
The sticky at the top contains the minimum fittings you must have to get a vehicle reregistered as a camper with the DVLA.
The information I have supplied is part of the Gas safety and use regulations (I am a Heating Engineer and have the gas qualifications required to work on Leisure Accomodation Vehicles)
The DVLA regulations do not take installation practice or safety into account, they only say what you must have, not what you must fit.
Tell me what you are planning on doing and I will try to advise accordingly
Postby AK » Wed Apr 27, 2011 9:13 pm
hm not had a good day, got a call from the guy paining my bumper and mirror caps, the paint isn't sticking to the bumper etc.
Now he is a good painterso I know used the correct platic primer etc.
Looks like the bumpers are caed in silicon, which is a nightmare to get rid off, the only thing I can think of is its something the dealer used to tart up the van when trying to sell it, and I;ve not had it long so there is still loads of remains of silicon on the bumpers.
The mirror covers are fine but I bought new from Ford, so its looking like the easiest option s to get a new bumper to pant.
On the plus side the chrome door handles arrived so there at least fitted.
Andrew
59 plate merc splinter Luton, 56 plate 100 TDCI 350 Crew/Camper conversion
AK
Postby AK » Thu Apr 28, 2011 2:13 pm
Andrew
AK
Postby AK » Thu Apr 28, 2011 5:42 pm
Population reducer arrived today so I had to have a dummy fit of it
Andrew
AK
Postby simon raymond » Fri Apr 29, 2011 11:46 pm
also like the job so far, i've also bought a network rail 06 plate, stripped and as you say takes more time than you think! im interested to know if you matched the roof lining material with what was fitted when you got it as mine was only lined to the partition, where did you get it from if so?? :?:
simon raymond
Postby AK » Sat Apr 30, 2011 1:28 pm
The roof lining isn't matched to the original as like yours its only lined to the partion, I bought my lining from
http://www.megavanmats.com/apps/webstore/products/show/2026379
However if you can get a corded version then t would be pretty much a 99% match depening on colour. The deal above was just about enough for me to do the whole job.
A few more pis as the side bars arrived today so i've been out fitting them this morning.
Still need some adjustment
Next job is to find some alloys I like and can afford
Andrew
AK
Postby AK » Wed May 04, 2011 4:50 pm
Rims arrived today
Andrew
AK
Postby AK » Mon May 09, 2011 3:44 pm
Front end finally done, still need to clean the centre bumper section
Not to everyones taste but I kind of like it just needs some small spot lights now
Andrew
AK
Postby blue estate » Mon May 09, 2011 3:50 pm
Looking good 8) i like the front as the white on the outer bumper looks better than the trend and limited spec with the white centre and grey outer : :D
And yes you do need some spots on that kidi catcher :wink:
blue estate
Postby Azer van man » Mon May 09, 2011 9:32 pm
Mate...that's a Top job you've done there..bloody marvellous :wink: 8) 8) Love the front end :wink:
Azer van man
