adapting wheels to fit mk 1?
Postby mavis cruet » Sun May 29, 2011 10:03 pm
i have a mk1 swb camper and have been wanting to fit some snazzy wheels for a while. idealy i want wolfrace slot mags or brm style (classic vw beetle). i can find ones with five studs, but never the correct spacing. is it safe to get them re-drilled to suit then weld the old holes up? i am assuming it is easier to get existing 5 stud rather than 4 stud? i realise i need to measure the offset and width and all that stuff. any ideas appreciated. karl.
mavis cruet
Re: adapting wheels to fit mk 1?
Postby Luke » Sun May 29, 2011 10:08 pm
if you have a mk1 or mk2 5 studder the front hubs dont have the indentation the mk3-5's have so you can get those redrilled dead easy - then just have some adapters made up for the back - thats what i'm doing for my mk1 :D
Postby pat stevens » Mon May 30, 2011 10:23 am
just had mine done for front of mk1 used mk2 hubs had them redrilled to jag chevy pattern theve come out a bit close to the original transit holes but once ive welded them up will be ok (prob be ok with holes in but i just want to weld them for looks). also what ive had done to them is the 5, 17mm bolts that hold the disc to the hub countersunk so i could use countersunk hex bolts leaves plate smooth and dont foul back if wheels ,they cost me £50.00 from a guy in wolverhampton whos got a machine shop.i also treated it to some brand new discs off ebay for £10.00 a pair
if its got tits or wheels its always gonna end in trouble !!!
anyone can restore a van but it takes a real man to chop it up !!!
pat stevens
Postby Luke » Mon May 30, 2011 10:42 am
got any pics of your hubs pat :?:
i had some done 112x5 merc patten a few years back :D
Postby pat stevens » Mon May 30, 2011 12:04 pm
ill take some later and put them on
pat stevens
Postby pat stevens » Sat Jun 04, 2011 3:17 pm
finally rememberd to take pic of re drilled hobs i had done
pat stevens
Postby Luke » Sat Jun 04, 2011 3:18 pm
cheers pat 8)
Postby pat stevens » Sat Jun 04, 2011 3:21 pm
must admit their as i collected them i havnt had time to do anythin on van since i started welding m8s capri
pat stevens
Postby Luke » Sat Jun 04, 2011 3:22 pm
it's a shame the later transits dont redrill as easy as the mk1-2s i think we'd be seeing a lot more customised vans :D
Postby pat stevens » Sat Jun 04, 2011 3:28 pm
yeah i know the same guy dit the ones for the guy who bought my big wheeled mk 5
dont know exactly how he did them but it was much wider stud pattern on the slot mags off some 4x4
so it mightve missed the recessed part of the hub flange
pat stevens
Postby pat stevens » Sun Jun 05, 2011 8:41 pm
now its come to a head with the local authority about the vans these are for sale if their any good to anyone theres the 2 hubs i paid £50 to have drilled and 2 brand new solid discs if it helps anyone out they can have em for £50 plus postage (better if you can collect due to weight )
pat stevens
