V6 Conversion Parts Checklist - Help Required
Postby bagss2 » Tue Jun 07, 2011 10:53 pm
Hi folks,
Having enjoyed my Pinto-powered Mk4 (SWB hi-top part-camper conversion) for the last few months, the decision has been made that she is a 'keeper' - and that more power is needed! :D
I have started stock-piling the necessary bits for a V6 (cologne) conversion, so far I have the following:
* Full Engine, Loom & all Anciliaries (2.8 Efi (super-rare!) out of a pal's dad's old funeral limo - so v low mileage)
* Transit 2.9 SVO Flywheel
* Transit 2.9 SVO Radiator & all Water Pipes
* Transit 2.9 SVO Engine Mounts
* Transit 2.9 SVO Adaptor Plate & Starter Motor
I am planning to keep the existing MT75 gearbox, prop & diff that's already in the van.
I know I need to get hold of the following:
* New Clutch Kit - does this need to be a 2.9 Transit kit presumably?
* Efi Petrol Tank & Pump
I have read that the Granada exhaust manifolds and downpipes cause an issue (they don't clear the bulkhead and/or Transit gearbox?) - am I correct in understanding that Capri 2.8i Janspeed tubular manifolds will cure this?
I am hoping to do as little 'fabricating' as possible. On this basis, what else will I need?
Many thanks in advance for your help!
Cheers, Baggers. :)
bagss2
Re: V6 Conversion Parts Checklist - Help Required
Postby Luke » Tue Jun 07, 2011 11:05 pm
not sure on the tubular manifolds - they may do - its the adapter plate and large transit bellhousing they catch - you could trial fit them on the floor 1st :idea: if they didnt fit tubular ones wouldnt take much modifying :D
Postby Luke » Tue Jun 07, 2011 11:07 pm
and apart from that your list looks pritty complete :D the only thing i can think of is the V6 slam panel is different so the large fan doesnt catch but thats not a problem to get round :)
Postby bagss2 » Tue Jun 07, 2011 11:15 pm
Luke wrote:not sure on the tubular manifolds - they may do - its the adapter plate and large transit bellhousing they catch - you could trial fit them on the floor 1st :idea: if they didnt fit tubular ones wouldnt take much modifying :D
Thanks Luke. I just did a search again and found this post:
BROWNYS V6 wrote:dunno how much room you got in there for them cast exhaust manifolds, you will find it easier with a pair of tubular janspeed ones for a capri :wink:
On this thread: http://fordtransit.org/forum/viewtopic.php?f=15&t=70073&hilit=capri+janspeed
Presumably though the Granada manifolds & downpipes deffo won't fit? Do people normally have to knock their own up or have some specially made?
bagss2
Postby bagss2 » Tue Jun 07, 2011 11:16 pm
Luke wrote:and apart from that your list looks pritty complete :D the only thing i can think of is the V6 slam panel is different so the large fan doesnt catch but thats not a problem to get round :)
Thanks. Will the standard slam panel need some cutting then? :?
bagss2
Postby bagss2 » Tue Jun 07, 2011 11:17 pm
Sorry, double-post :oops:
bagss2
Postby Luke » Tue Jun 07, 2011 11:17 pm
well for a 2.8 you cant get them for a transit as they were 3.0 essex or 2.9 cologne
alanN has a 2.8 in his was that the thread with brownys comment :?:
Postby Luke » Tue Jun 07, 2011 11:19 pm
no i think you can fit a smaller fan :? not really sure plenty of v6's have gone in no bother - i only noticed as i had both side by side (i had a mk3 svo v6 ambliance) :D
Postby bagss2 » Tue Jun 07, 2011 11:22 pm
Luke wrote:well for a 2.8 you cant get them for a transit as they were 3.0 essex or 2.9 cologne
Do you mean exhause manifolds & downpipes?
Are the manifolds different on 2.8s and 2.9s?
Luke wrote:alanN has a 2.8 in his was that the thread with brownys comment :?:
No, the thread I linked to above, where a member was 'mocking up' for his conversion...
bagss2
Postby Luke » Tue Jun 07, 2011 11:24 pm
yes manifolds mainly and they are different on a 2.8 to 2.9 - but 2.8 is easier to get hold of tubular ones :D
Postby AlanN » Wed Jun 08, 2011 12:22 am
the 2.8 has siamese ports (2 outlets each side) the 2.9 has 3 each side. tubular manifolds are easy to get for the 2.8 and Ive only ever seen custom made tubular ones for the 2.9 ££££
I sure the down pipes on the SVO ambi are bent really wide to clear the box with the O/S one having to clear the oil filter too, but Im sure you will be able to adapt a pair of capri ones
:( Image
Postby bagss2 » Wed Jun 08, 2011 8:41 am
AlanN wrote:the 2.8 has siamese ports (2 outlets each side) the 2.9 has 3 each side. tubular manifolds are easy to get for the 2.8 and Ive only ever seen custom made tubular ones for the 2.9 ££££
Thanks Alan.
What did you use for your conversion?
Cheers, Baggers.
bagss2
Postby AlanN » Wed Jun 08, 2011 2:34 pm
I used a Granada MKII 2.8i onto a C3 auto box, I brought Capri tubular manifolds,which clear the box and filter with no issues but I am going to fit a A4LD from a Transit eventually and there shouldn't be any clearance problems with that either.
Postby bagss2 » Wed Jun 08, 2011 6:37 pm
AlanN wrote:I used a Granada MKII 2.8i onto a C3 auto box, I brought Capri tubular manifolds,which clear the box and filter with no issues but I am going to fit a A4LD from a Transit eventually and there shouldn't be any clearance problems with that either.
Cool! :D
I am going for a similar engine, mated to the MT75 transit 'box with the correct adaptor plate.
So, with Capri tubular manifolds should get around it?
Did you then mate them to your old transit exhaust system - or get a custom exhaust made up? :?:
bagss2
Postby Luke » Wed Jun 08, 2011 6:39 pm
any exhaust will fit round an autobox they are much smaller :) its the transit manual MT75 what causes the problem :(
