24v Cossie 2.9 into a Mk3 ..... starting out ...... :)
Postby dipstick » Tue Sep 26, 2006 8:45 am
Just for info really, i have finally got most of the bits required to put my 24v Cossie v6 into my Mk3. I found a police-spec 2.9 V6 with the adapter plate, engine mounts and MT75 still attached....
I have started to strip the large bits down for cleaning prior to trial assembly, so if anyone wants any photos or diagrams of any bits, i will be putting some digis up on the web soon as......
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Tue Sep 26, 2006 6:08 pm
Can you do a template of the adaptor plate and put measurements on it and post it up
2005 Ford F250 Super Duty
1992 MK3 ambulance
1980 A Series crew cab
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Wed Sep 27, 2006 10:45 am
.... :) sure, if i can get the time, i will take it to a place near me and get a quote for replicating it, it is 'just ' a piece of 5/8" or so steel, ha ha
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Guy88 » Wed Sep 27, 2006 6:08 pm
I onlt need to know measurements. i allready got a pinto one to mod :D
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby dipstick » Wed Sep 27, 2006 8:38 pm
OK, i am with you.... where in the world are you? I can get it cleaned up and measured this weekend....
cheers :-)
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Sep 27, 2006 9:03 pm
rather than measuring it wouldnt it be best to use a spacer off a v6 (doesnt the cossy have one?) to use as a template and drill through :?
the plate needs to be exactly right :D
Postby dipstick » Wed Sep 27, 2006 9:20 pm
Luke, what spacer do you mean, the adapter plate, or something else?....
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Sep 27, 2006 9:30 pm
dipstick wrote:Luke, what spacer do you mean, the adapter plate, or something else?....
these things :lol:
the one on the left is from an xr4x4 same engine as the 24v, what i mean is place that over the pinto plate and drill through - obviously doing it in a exact way :lol:
Postby dipstick » Wed Sep 27, 2006 9:36 pm
hmmmm, that is an idea... :)
can't think why it wouldn't work...?
i have noticed that the adapter plate that i have, has some holes recessed to take bolts that have heads 'flush' with the surface of the plate, specifically the top two.
i agree that it needs to be spot on... :-)
are you doing a 24v tranny? if so, how is it coming along?
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Wed Sep 27, 2006 9:45 pm
yeah mate im putting one in my mk1 :D hopefully it will be done by october .................................... 2008 :lol:
ive got the transit bits i just need the 24v engine :D
aslo as you have a tranny V6 box do you know if the input shaft is different to the Di one :?:
i have one but its still in van and i havent had time to split it yet :x
Postby Guy88 » Wed Sep 27, 2006 10:08 pm
Luke i never actually thort of that :lol: :lol: i think thats what il do.
As for the input shaft i think the V6 is longer. I am going to use the torque converter spacer to hold the spigot bearing same as Oxtony 8)
1992 MK3 ambulance
1984 A series RB44
LIVIN' LOUD
Guy88
Postby Luke » Wed Sep 27, 2006 10:12 pm
Guy88 wrote:Luke i never actually thort of that :lol: :lol: i think thats what il do.
i know the V6 is longer but so is the Di what we need to know is the Di the same as the V6 :? :lol:
Postby dipstick » Thu Sep 28, 2006 9:22 am
Luke ,
I have a Di MT75 next to the V6 MT75 in my garden at the mo, give me a few hours and will compare and contrast... :-)
cheers
dipstick
Cosworth Powered
Cosworth Powered
Postby dipstick » Thu Sep 28, 2006 11:42 am
Luke, i have just got the two MT75s next to each other, yes the input shaft is the same, they both stick out approx 5mm from the front face of the 'box.
I cannot see any differences between the two boxes at all, on the outside anyway!
I hope this helps in some way.... Cheers :-)
dipstick
Cosworth Powered
Cosworth Powered
Postby Luke » Thu Sep 28, 2006 12:12 pm
excellent 8) :lol: i suspected but you never know that means if anyones V6 box busts they wont have a problem getting a replacement!!! 8)
